SES light on, getting code P1316 - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-28-2013, 08:20 AM Thread Starter
I bought a 2001 F350 7.3 6 speed a couple months back with 211k, now at 218k, and it's run great up until yesterday. I was towing a 10k? trailer, and everything felt fine, and all of a sudden, whenever I hit a hill, the SES light would flicker on and the engine would sound like it was missing. It would go away as soon as I topped the hill. This happened a couple of times, and then the light stayed on after the hill. I stopped in the next town, 12 miles from where the problem first came up. Starting from a stop was a real challenge, like I had now power. Starting from a stop up any kind of hill required low gear. I pulled up at a carquest, the engine was idling real rough, and then died like the key was turned and wouldn't restart. I borrowed a scanner from the carquest, but couldn't figure out how to make it talk to the truck so I went ahead and replaced the CPS. After this, the truck started fine, but all the other problems were still present. I started playing around with the scanner more and got it to work, and it returned code p1316. I tried clearing the codes, and that did nothing. Next I found a mechanic with a genesis scanner, and he pulled a code for the accelerator position sensor. I replaced that, and it didn't seem to make any difference. I've tried disconnecting the batteries to reset the computer, and I've plugged in a basic scan tool I had at home, which found no codes present, despite the fact that the SES light is on. I tried clearing codes with the scanner, the SES light flickers but stays on, and the scanner says the erase failed. The engine starts great, but runs rough up to about 1500 rpms. The truck has low power, starting out in low is almost required with the trailer on behind, and hills I should be able to pull at 65 are now 45 mph. Where should I check next?
TempestV is offline
post #2 of 12 Old 07-28-2013, 08:49 AM
jesilvas's Avatar
Quoted: 2 Post(s)
You need a good scanner that can read live data, and not just pull codes.
You may have low high-pressure-oil pressure, low low-pressure-oil pressure, low fuel pressure, low boost, stuck exhaust back pressure valve, and so on.
But usually a P1316 is either InjectorDriverModule (IDM) issue, or wiring issue with your UnderValveCoverHarness, both of which supply power to the injcetors. I'd check the harness connections just outside the valve covers first, easy fix.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 12 Old 07-28-2013, 09:30 AM Thread Starter
I checked the UVCH plugs, both were in tight. I unplugged them, blew them off and made sure that they were in good and tight, and it didn't make a difference. I tried unplugging them while the truck was running, both made the truck idle worse, but unplugging the passenger side had more of an effect than the drivers side. I'm going to try running the driver side pins with my meter.
TempestV is offline
post #4 of 12 Old 07-28-2013, 10:00 AM Thread Starter
I think I found the problem- checking resistance to the center pin on the drivers side VCGH, one pin read 0 ohm. The other three read 2.9-3.1
TempestV is offline
post #5 of 12 Old 07-28-2013, 10:45 AM
jesilvas's Avatar
Quoted: 2 Post(s)
IIRC there are nine pins on there.
(GP) (GP) (Inj) (Inj) (Ground) (Inj) (Inj) (GP) (GP)
So center will be zero ohms.
http://www.powerstroke.org/forum/7-3...ould-have.html
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 12 Old 07-28-2013, 12:56 PM Thread Starter
Right, I read from the center ground to each of the injector pins, and the pin directly behind the ground read zero ohms, the other three read roughly 3 ohms.
TempestV is offline
post #7 of 12 Old 07-28-2013, 01:06 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Oh gotcha. If it was 0 ohms, that means it was grounded out. I'd check the harness under the valve cover, or do a buzz and cylinder contribution test first.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 12 Old 07-28-2013, 01:36 PM Thread Starter
The buzz test is what I asked the mechanic to run yesterday, and then he found that TPS code, and said that was the problem. I'll pull off the valve cover and see if I can find the problem.
TempestV is offline
post #9 of 12 Old 07-28-2013, 01:37 PM
jesilvas's Avatar
Quoted: 2 Post(s)
If he over ruled you and didn't run the buzz test, I wouldn't take it back.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 12 Old 07-28-2013, 05:06 PM Thread Starter
I got the valve covers off, here's what I found:
Does the center ground pin look burnt?
Harness side:
Gasket side:
Wire running to the injector that was running 0 ohms:
I've got the new gasket/harness, as soon as the rain lets up I'm going to go get everything back together.
TempestV is offline
