02 7.3L - burns oil/loss of power/more smoke - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-18-2013, 07:41 PM Thread Starter
Feedback Score: 3 reviews
My 02 F350 7.3L has 170,000 miles on it, and was getting oil in the fuel back in the winter/early spring. I pulled the injectors and replaced all of the O-rings (3 injectors had some pretty bad O-rings) about 2 months ago. Im still burning oil, smoking more than usual, and I seem to notice a loss in power on the low end.
I towed my in-laws 27' bumper-pull camping trailer and noticed that just accelerating and driving with just a slight load makes the truck smoke (dual exhaust, can see the smoke against the white trailer). It seems like driving without towing, its a little slow off the line and once it hits 2nd gear its fine.
Specs on the truck:
7.3L 170,000 miles
DP tuner
AFE stage 2 intake
MBRP exhaust
ATS transmission
38" tires, 4.56 gears
Problems:
Burning oil
more smoke than normal
loss of power on the low end
What Ive done:
Injector O-rings
Any ideas as to where I can look to help take care of my issues?
02 F350 7.3L Lariat; DP tuner, AFE stage II intake, AFE intake manifold, dual 4" exhaust, ATS trans, Autometer gauges, Superlift 8",
38" Toyos, 20" Provo's, Amp Powersteps, 05-07 Front end Conversion, KDfabworks bumper bracket with CSI 20" LED....
kjdavis is offline
post #2 of 7 Old 07-23-2013, 03:29 PM Thread Starter
As a bit of an update, I checked the fuel bowl and there are no longer any visible signs of oil in the fuel. Before I did the injector O-rings, the fuel was dark, and you could see tiny oil droplets. Its all clean now.
So, the oil is going somewhere else...turbo? The exhaust does smell like oil.
kjdavis is offline
post #3 of 7 Old 07-23-2013, 04:00 PM
Quoted: 761 Post(s)
Not necessarily the turbo. Could of pinched a new O-ring upon installation. Injector may not have seated all the way during torquing them down, or possibly a bad injector.
Do a buzz test, then CCT. If those pass then start the truck, let it idle for 30 seconds to a minute, then remove the downpipe and look for fresh oil in the turbo and the intake pipes too. Some oil on the intake side will be normal dye to the CCV, unless you have it routed different. It will definitely be more obvious if its oil coming from the injectors or turbo. Typically its going to be an injector issue. But not always.
Corey@CNCFAB is offline
post #4 of 7 Old 07-23-2013, 06:45 PM Thread Starter
thanks for the response, I appreciate the suggestions. what's the buzz test, and also CCT?
kjdavis is offline
post #5 of 7 Old 07-23-2013, 08:34 PM
Quoted: 761 Post(s)
Buzz test will excite the solenoids on the injectors when engine is not running. Do a YouTube search and you'll understand.
CCT is a Cylinder Contribution Test. Kind of self explanatory I guess. You will have to have someone with the proper diagnostic tools to do these. Dealers have it or someone you know that has the more expensive ScanGauge or AutoEnginuity software. A simple code reader will not work at autozone etc.
post #6 of 7 Old 07-25-2013, 01:48 PM Thread Starter
Perfect. Thanks for the info!
I need to do the International up-pipes anyway, so I may just replace the seals and rebuild the turbo anyway while its off since the kit is only about $75.
Ill try the other stuff too. Thanks again!
kjdavis is offline
post #7 of 7 Old 07-27-2013, 12:39 PM
I replaced an injector and I somehow damaged an o-ring when I did it. I was even going to skip that cylinder when I was replacing them. Good thing I did. Mine was consuming a LOT of oil!!! Food for thought.
quadscrib is offline
