!!!HELP!!! NO DRIVER SIDE INJECTORS - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-18-2013, 02:01 PM Thread Starter
jpalma's Avatar
So I started my truck up today to go to lunch and it would barley stay running. Tried to take it around the parking lot and it would die. Ran codes and got P1316, looked into it further found that all of my driver side exhaust manifold were at ambient temp while the passenger side heated up to operating temperature. Ripped out the valve cover in the middle of the parking lot noticed the wire harness underneath was a little loose so I did the quarter trick online that I found to keep everything tight. Put everything back together and still nothing. WHATS GOING ON??
Is it possible I fried some of those wires in there and need a new harness??
HELP PLEASE I need my truck.
Thanks, Josh
2000 F250 Crew Cab, 366,500miles
,6637,Foil delete, Smoked Cab lights, Bed Liner Rockers, Muff. Delete,08 DIff Cover, 50 Gal Transfer Flow Tank
jpalma is offline
post #2 of 10 Old 07-18-2013, 02:54 PM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
Either the IDM has gone bad, or the connector is not "connecting" (despite being locked securely back in) because the pins are now burned.
Did you look into the connector and examine the pins before you plugged it back in?
At this point, I'd be leaning towards an IDM as the most likely problem (they have a poor seal and often get water inside that can kill the output to one, or both sides). You could measure the resistance going to the injectors, in both sides, as a comparison before you invested in an IDM. Or, alternatively, try to "borrow" one as a test (for functioning purposes, they're all the same....)
NoRalPh is offline
post #3 of 10 Old 07-18-2013, 03:35 PM Thread Starter
jpalma's Avatar
The pins look fine inside but just did some examining on the connector that goes into the valve cover and it is all frayed and wires exposed. I wanted to do new glow plugs anyway so I just picked up the new harness and pigtail and will do that this weekend.
jpalma is offline
post #4 of 10 Old 07-19-2013, 02:23 AM
Your IDM may be fried as well. Mine did the same thing on passenger side where engine harness plugs into vc gasket. The insulation on the wires deteriorated and when they touched took out the IDM. New IDM and connector and we're good to go.
lhw1172 is offline
post #5 of 10 Old 07-19-2013, 06:06 AM Thread Starter
jpalma's Avatar
If the IDM was bad wouldn't both sides not be firing? My truck still runs on the passenger side. Well I already got the new improved gasket and the pigtail so I will put those in hopefully that will do the trick. If not I will have to track down a IDM.
jpalma is offline
post #6 of 10 Old 07-19-2013, 07:08 AM
Quoted: 143 Post(s)
No, a bad IDM might well just be bad on one side only...
NoRalPh is offline
post #7 of 10 Old 07-19-2013, 07:17 AM Thread Starter
jpalma's Avatar
Well crap. Know any good places to pick one of those up just in case I end up needing to order one?
jpalma is offline
post #8 of 10 Old 07-19-2013, 07:23 AM Thread Starter
jpalma's Avatar
2001 2002 FORD 7.3L DIESEL MODULE XC3F AB IDM 120 on eBay!
To cheap?
Is there a way to test the IDM to tell if it is bad? I would like to get one ordered before Saturday afternoon when I am done putting the valve covers back on.
Or anyone know the correct part number?
jpalma is offline
post #9 of 10 Old 07-19-2013, 07:57 AM
Quoted: 143 Post(s)
To cheap?
I donno Even cheaper? -> Ford 7 3L Diesel Powerstroke Injector Driver Module IDM Factory Rebiult | eBay
The test for a bad IDM (at least the only one I know...) is a quick swap. That's why I suggested the "borrow" if you know anyone else with a 7.3 because it's a quick & easy thing to do. That's why I have a spare!
Who ever sells you a new one will know the right P/N I hope. As I said, there's Little difference between them and Anyone of them will function...
NoRalPh is offline
post #10 of 10 Old 07-20-2013, 01:34 PM Thread Starter
jpalma's Avatar
All fixed! New Dorman harness/gasket installed, no idm needed. Installed all new glow plugs. Even found one glow plug, the connector wire was burnt through.
Thanks for all the help guys!
jpalma is offline
