No start - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-17-2013, 07:02 AM Thread Starter
USMC2001PSD7.3's Avatar
Quoted: 15 Post(s)
Garage
No start
Need some input. I'm out of town for a few weeks and my wife has the truck. It has always cranked right up and never had a starting issue.
She says when as soon as the wait to start light goes off she will turn the key forward and it clicks once then nothing. It has battery power so that leads me to maybe the starter or cam position sensor. Any input is appreciated.
USMC2001PSD7.3 is offline
post #2 of 11 Old 07-17-2013, 08:24 AM
timmyboy76's Avatar
if its clicking and motor isn't turning over, then you either have a battery issue or relay issue. Possibly a bad starter as well.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 11 Old 07-17-2013, 05:14 PM
I would try the starter relay first. It should be mounted on the passenger side. It goes out all the time on these fords. I think they used a similar relay for many years (plus much cheaper than a starter).
00 Excursion 7.3 (1.0 Ex. hsng., 3.5" downpipe, Aero Muffler, Banks WG, Banks Comp. Wheel, AFE Stage 2 Air intake, HPX, IAH delete, DP- Tuner F6, Riffraff Boost Fooler, Melling Oil Pump), Fuel lab 41402 pump and regulator, fuel bowl delete, 910 Comp Springs/Shims, DI Pushrods, Swamps HVHF IDM, SRP 1.1 HPOP Dieselsite trans and coolant filter, 203* thermostat, Sonnax valve 0.427 and tricumulator springs, Lift, MM Hubs, 35's and 3.73s, 08 diff cover, Hellwig rr. bar
326RWHP @ 731RWTQ.
572ysc is offline
post #4 of 11 Old 07-17-2013, 05:54 PM Thread Starter
Quoted: 15 Post(s)
Garage
That's what I'm thinking. I will be back in bout a week so ill look at the starter and relay first. I wouldn't think the batteries are bad because it shows good voltage. When you turn the key it clicks once so ill start with the relay. Anybody know of good aftermarket starters or relay upgrades like the stancor relay upgrade
post #5 of 11 Old 07-17-2013, 06:09 PM
I use the Echlin relay from napa it seems to work fine.
326RWHP @ 731RWTQ.
572ysc is offline
post #6 of 11 Old 07-17-2013, 06:11 PM
aussie=effie
bob harris's Avatar
no start
may just be loose or dirty battery conection
bob harris is offline
post #7 of 11 Old 07-18-2013, 04:15 AM Thread Starter
Quoted: 15 Post(s)
Garage
Ill check the connections of course first. I have a friend looking at it and he has an 01 7.3 too and he checked batteries and they're good
post #8 of 11 Old 07-18-2013, 08:55 AM
Quoted: 177 Post(s)
Feedback Score: 3 reviews
I'm going to assume you've got an '01
So, there was a major electrical change in the MY. IF you have a Trans Temp Gauge in the Instrument Cluster, you Do Not have a Starter Solenoid on the pass fenderwell under the hood. If you don't have that TT gauge, you Do.
This is important because it's a good place for a mid-point check. WHAT is it that's making the "click" you hear? Check that the Headlights aren't going Dim & Yellow when you roll the key to the start position too.
NoRalPh is offline
post #9 of 11 Old 07-19-2013, 04:54 AM Thread Starter
Quoted: 15 Post(s)
Garage
Ill have to check when I get back in town. Y'all know how it is when someone else tells you what your truck is doing. I gotta see for myself. Ill definitely check for the guage you mentioned
post #10 of 11 Old 07-26-2013, 07:29 AM Thread Starter
Quoted: 15 Post(s)
Garage
It started right up! They didn't have it in park or neutral hahaha
