Key out Battery light and theft light - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-16-2013, 02:31 AM Thread Starter
So after driving the Excursion to and from D.C. yesterday (ran great) I tried to move it after I got home. The battery light is on with the key out of the ignition. In addition, when you turn the key the light goes off and the theft light blinks and it won't start. Any ideas on what the problem might be?
I was thinking that it might be the alternator or something with the ignition switch.
Thanks for your help.
00 Excursion 7.3 (1.0 Ex. hsng., 3.5" downpipe, Aero Muffler, Banks WG, Banks Comp. Wheel, AFE Stage 2 Air intake, HPX, IAH delete, DP- Tuner F6, Riffraff Boost Fooler, Melling Oil Pump), Fuel lab 41402 pump and regulator, fuel bowl delete, 910 Comp Springs/Shims, DI Pushrods, Swamps HVHF IDM, SRP 1.1 HPOP Dieselsite trans and coolant filter, 203* thermostat, Sonnax valve 0.427 and tricumulator springs, Lift, MM Hubs, 35's and 3.73s, 08 diff cover, Hellwig rr. bar
326RWHP @ 731RWTQ.
572ysc is offline
post #2 of 2 Old 07-16-2013, 04:29 PM Thread Starter
Found the problem. It was a shorted alternator plug harness, which bypassed the alternator diode. Easy way to check was to remove the fuse.
326RWHP @ 731RWTQ.
572ysc is offline
