02 7.3 rough idle then stalls - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-14-2013, 01:59 PM Thread Starter
Buckeyepsd's Avatar
Quoted: 3 Post(s)
Truck starts then idles like a muscle car with a huge cam in it then dies. I changed the ICP and CPS. Haven't scanned it yet but any ideas?
Sent from AutoGuide.com App
02 F250 CCSB Lariat 4x4
38R, Rosewood Stg 1's, AFE Stg 2, 4" Turbo Back, Tuned, Tranny, 4" Lift
Buckeyepsd is offline
post #2 of 7 Old 08-07-2013, 01:13 PM
Have any luck figuring this out? Mine has a similar issue. Sounds like a muscle car when you start it up. Sputters when you apply throttle, but smooths out over 1k. If I rev it up it will just die when it comes back down. When its at idle and sounding like a muscle car I can put it in gear and it goes away. Are/were you having a similar problem?
gkinney_1 is offline
post #3 of 7 Old 10-05-2013, 06:08 AM Thread Starter
Buckeyepsd's Avatar
Quoted: 3 Post(s)
I still have no clue why mine is doing it. It's not throwing any codes. I just dropped it off at Unlimited Diesel Performance in Bremen, Ohio. They are pretty confident that they will be able to find it and fix it. They told me there is a high probability that it is an IPR valve issue. So we will see. Once I get the truck back I will reply to this post to let you know what they found.
post #4 of 7 Old 10-08-2013, 07:51 AM
Thanks, I appreciate it. I've been chasing mine for quite sometime now.
post #5 of 7 Old 12-14-2015, 08:34 AM
Any news on what this was? Experiencing exact same issue now.
Thanks
JohnWynneIrvine is offline
post #6 of 7 Old 12-14-2015, 11:25 AM
Quoted: 175 Post(s)
Feedback Score: 3 reviews
Get it running for a min or so (assuming it's cold when you do this) and go feel the Exhaust Manifolds (over the top of the Ft Tires) and compare them for Heat. Are they both the same?
If one side stays cool then you may be running on 4clys because that sides injectors aren't firing because of a bad connection (UVCH) or IDM...
NoRalPh is offline
post #7 of 7 Old 06-20-2016, 07:57 PM Thread Starter
Buckeyepsd's Avatar
Quoted: 3 Post(s)
Sorry for the lack of updates. It ended up being an unseated injector and 2 others that were cracked......I should have trusted my gut and went with it. It would have saved me some serious $$$.
