7.3 Running Rough Problem - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-13-2013, 05:43 PM Thread Starter
Powerstroke Man 6.4's Avatar
Okay I have a 1999 7.3 just installed TE T500 HPOP and Garret GTP38R with WW2. Truck ran fine drove it for 2 weeks then found fuel leaking the fuel lines on the cylinder heads. They were cracked installed new lines from ford torqued them down correctly no fuel leaks now and now the truck is missing when started up the truck lopes for about 40 seconds before it idles and when it does sounds like its missing real bad. no DTC codes and doesn't idle when cold and when warm it only idles on stage 3 ( 140 DP Tune ) stage 1 stock and stage 2 80 tow it wants to dies has no power at all and it white smokes only when cold. Please Help like I said no DTC's. thanks in advance the truck is going to Ford on monday.
2012 Ford F-350 SRW 3.55 LS Lariat Blk Crew Cab Spartan 200 Hp Tune Warhammered 5 In MBRP EX AFe S 2 CAI
2008 Ford F-350 White XLT Crew Cab DRW
MPRP 4 IN Downpipe Back DPF Cat Delete Stright Pipe Spartan 300 LL Tune AFe ST 2 CAI MBRP 3 IN Intercooler Pipe. 4.30 LS
Late 1999 Ford F-250 XLT X-tra Cab White 7.3 SRW 6637 MBRP 4 IN Turbo Back Exhaust No Muffler DP-Tuner And PHP Hydra T-500 Swamps 160/100% Inj Airdog Swamps HVHF IDM GTP38R W WW2 305,000 MI 3.73 Non LS
Powerstroke Man 6.4 is offline
post #2 of 10 Old 07-13-2013, 05:49 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Check the Injector harness that runs into the valve cover, especially the passenger side one.
The passenger fuel line runs right near that connector and I wouldn't be surprised if its been bumped loose.
Check anything else in the area just in case too. I've heard major horror stories about mechanics not paying enough attention because of their hurry under the hoods of these thins.
schlutzer is offline
post #3 of 10 Old 07-13-2013, 06:02 PM Thread Starter
Checked The injector harness on both sides making good contact and same thing.
post #4 of 10 Old 07-13-2013, 06:51 PM
schlutzer's Avatar
Quoted: 18 Post(s)
You took off the valve covers in 13 minutes?
It's more likely that the inside one has come loose, mine ohm'd fine. But the passenger side was nearly out on the inside. And had very similar symptoms.
post #5 of 10 Old 07-13-2013, 11:02 PM Thread Starter
I had the valve covers off already. Connectors were full seated Left Hand VC and Right Hand VC and same thing.
post #6 of 10 Old 07-14-2013, 12:45 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Okay fair enough.
I would wonder if that aftermarket HPOP is no good. Have you got a way to check HPOP pressure? I know the T500 is great I plan to get one myself, just saying its possible.
Could also unplug the ICP and see if it gets better or worse.
On a side note, my truck runs like absolute garbage if the oil level is down even just a bit. It's worth the check to pull the dipstick if you haven't already.
post #7 of 10 Old 07-14-2013, 02:13 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Either with a manual gauge (that can do 3500 psi most people don't have that).
Or with a fancy scan tool.
Most of my ideas will revolve around a scan tool. About the only other suggestion I could make is remove the DP and see what happens. If the connection got crappy it can cause weird issues, I forget what exactly though.
You may have to grab some lube before Monday if you don't have access to a scan tool that can do our trucks.
post #8 of 10 Old 07-14-2013, 02:23 AM Thread Starter
Pulled ICP plug no change how could I check HPOP pressure like I said only started missing after I changed the fuel lines on the heads torqued them down correctly no leaking fuel whatsoever no cracks or bends in the lines oil was just changed when the TE T500 was installed 200 miles ago and the GTP38R was installed no leaking oil whatsoever Thanks for your help @schlutzer for replying to the thread and helping me out I really appreciate it.
post #9 of 10 Old 07-19-2013, 03:24 AM Thread Starter
schlutzer took the 7.3 to ford on Monday just found out whats wrong with it yesterday well. Here we go all (8) injectors tested bad UVCH pins were burnt Driver And passenger side so have to change that also Valve Cover Gaskets have to change fan belt ( I knew that ) was about to change it 3900.00 for the injectors 60.00 for the gaskets 200.00 for the UVCH both sides and 1500.00 labor. and misc parts for a total around $4200. Ford waiting on me now big dent in my wallet but still gotta love ford.
post #10 of 10 Old 08-10-2013, 08:52 PM Thread Starter
:Update
Schlutzer Decided to go with Swamps injectors 160/100% Stage 2 Single Shots
Other parts ordered:
Airdog 100 quick connect
Beans diesel tank sump kit
Swamp's diesel HVHF IDM
GlowShift Pyro Boost Trans
:Current Mods:
GTP38R W/ WW2
EBPV Delete Pedestal
DP F5 stock, 80 Tow 140 Aggressive
4in MBRP TB Exhaust
6637 Intake
TE T-500 HPOP
All the parts ordered will be here by next week Tuesday and installed on Thursday and the truck should be back on the road by Friday.
