Turbo whistling? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-09-2013, 09:10 AM Thread Starter
Turbo whistling?
2001 F250 7.3 auto, bought new, has a western diesel chip & boost tube in vac line going to waste gate. I was pulling a trailer weighing about 10,000 lbs up a grade, trans down shifted, engine rpm up, 1 loud pop & a whistling sound started. no more pop, whistles now on acceleration & pulling loads, is the waste gate stuck, truck still runs real good. went on a 1800 mile trip up hills & down with a 7000 lb trailer @ 75 just a whistling. What should I look for?
Steve
steve reynolds is offline
post #2 of 3 Old 07-09-2013, 09:50 AM
ADMIN AND TECH
SCUFFY828's Avatar
Steve
I don't know exactly what popped , I would say a possible boost leak, but if it was a bad enough leak then the power would be down at least some
ITS STOCK
SCUFFY828 is offline
post #3 of 3 Old 07-15-2013, 06:54 AM
DieselManor's Avatar
Check your intercooler boots. One of them most likely popped off and is loose. As mentioned, you should see a decrease in power though.
David Murphy
DieselManor is offline
