IDM codes detected, IDM fault - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-07-2013, 11:47 AM Thread Starter
IH333Stroker7.3's Avatar
Post IDM codes detected, IDM fault
i just added to my fleet a 2000 7.3 dually with 343*** miles on her. manual trans and everything is stock I believe. I picked the truck up for 800 bucks. first off its been sitting for a couple years, I put fresh batteries in it and checked all the fluids and bard over the engine first before I started it and then started it and it sounded great! and ran great until I took it down the road for a test run and Igot the engine light... bummer haha. any how the codes I pulled out of it was the p0237 which is cause I was unplugging the m.a.p, p0603 which is cause no keep alive, so im not worried about those. the ones im worried about is the p1316 IDM codes detected. after I got these codes I did a buzz test and it brought up injector #7 p0279, and it brought up the p1298 IDM fault. I then did some research and some were saying to check all under valve cover connections which I just did and all looks clean, connected and not burnt. I noticed that injector #5 looks the newest out of them all. I need some help I don't know if I need a new IDM or just an injector, it has no power, runs rough, just sounds really bad. if anyone can help out that would be so appreachative! just so ya know I have no history on this rig just heard about it, seen it, laughed at the price and brought it home... thanks, Dan.
IH333Stroker7.3 is offline
post #2 of 5 Old 07-07-2013, 02:41 PM Thread Starter
help?
do I need a new IDM? help.
post #3 of 5 Old 07-10-2013, 09:34 AM Thread Starter
Thanks for the help
Don't worry I figured it out . When in doubt call ford and bug there techs haha
post #4 of 5 Old 07-10-2013, 09:40 AM
MSTR-P's Avatar
what ended up being the issue?
'03 7.3 - Stock!
MSTR-P is offline
post #5 of 5 Old 07-10-2013, 02:19 PM Thread Starter
It was the harness on passenger side it was shorted to ground
Tags
idm , nopower , p0279 , p1298 , p1316
