'99 Ford F-550 Lacking Power & Rough Idle - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-06-2013, 01:30 PM Thread Starter
Hey fellas, Ive been reading almost on this website for years now. Solved every powerstroke related problem ive had. Although after hours of research i couldnt find a solution to my problem.
To make things short, my uncle bought me a 99' ford f550 from his friend since its a dump and ive got a landscaping company. always been a god guy
although its been 5 days since i had the truck and when i start it it idles really rough. it shakes the whole truck side to side and when the hood is open you can see the engine shaking as well. Also, i did drive it and there seems to be a lack in power. rpms do go up although it seems like if i hooked a 7 ton trailer to it, it would barely make it out the shop..
if u guys can help at all it would be greatly appreciated. i simply cant let a powerstroke off the road...... to many dodges out there
99-F550 is offline
post #2 of 11 Old 07-06-2013, 01:31 PM Thread Starter
to add to the truck, there is no white smoke or black smoke. seems to blow fine. black smoke when you get the rpms high in neutral
99-F550 is offline
post #3 of 11 Old 07-06-2013, 01:39 PM
timmyboy76's Avatar
might want to take a gander at the UVCH assy. Either its loose outside the vc's or under it. Look up 50 cent mod. You replace the fuel filter? Also, take a look at the HUTCH mod.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #4 of 11 Old 07-06-2013, 02:19 PM Thread Starter
Thanks for your reply. def going to take a look at the 50 cent mod. do you think it may be the injectors giving me the probs? had a powerstroke repair guy tell me he can take a look at the truck for 50 bucks and it may be injectors..
99-F550 is offline
post #5 of 11 Old 07-06-2013, 04:31 PM
timmyboy76's Avatar
you can ohm out the injectors and gp's while ur in there...with a loose connection, it can be anything. CEL / SES light on?
post #6 of 11 Old 07-06-2013, 04:32 PM
timmyboy76's Avatar
also, re-torque the injectors and rocker bolts
post #7 of 11 Old 07-06-2013, 06:56 PM Thread Starter
No lights on at all. Dash is clear. Truck only has 195000kms on it so it has a lot of life left in it. Also, being a dump truck i belive it was barely used by the electric company that owned it. although they could have done a better job servicing it. I appreciate you taking time out of your day to diagnose the issue. will definetly do all youve suggested.
99-F550 is offline
post #8 of 11 Old 07-06-2013, 07:10 PM
scagmanf350's Avatar
UVCH issue sounds like. Just replace the entire harness its not that bad I did it in an afternoon in my driveway. Also how long since last oil change?
1999 Ford F350 Crew Cab Dually 4WD 7.3 Powerstroke
scagmanf350 is offline
post #9 of 11 Old 07-07-2013, 09:07 AM Thread Starter
hey folks,
truck starts just like this one does. the comments have different responses. one guy says its the cps and theres a guy saying it may be the o-rings
99-F550 is offline
post #10 of 11 Old 07-07-2013, 09:26 AM
timmyboy76's Avatar
alright bud, your comparing a winter start vs a summer condition symptom. That truck in the video, more than likely, could be fixed with running synthetic oil..5w/40...(the romps).
Whens last oil change? fuel filter change?
