7.3 Will not stay running! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-05-2013, 11:51 AM Thread Starter
I have a 2002 F205 7.3L Diesel. The other day i was driving normally down the road when i quit. Just like i shut the key off. It wouldn't start. Let it sit about 1 hour and tried it and it started up. (no codes showing) I thought it was the CPS so i changed it. still the same problem. Then i tried spraying water on the motor to cool it then it would start right up, but die when it warmed up. I narrowed the spot to the HPOP. I can pour just a little water down there and it will start right back up. Could it be the IPR or a bad HPOP, or ICP sensor? Thanks, Daniel
dkoehn is offline
post #2 of 8 Old 07-08-2013, 02:23 PM
Quoted: 816 Post(s)
I'm thinking Arby's.
J/k. Might be the IPR. Strange but definitely possible.
Corey@CNCFAB is offline
post #3 of 8 Old 07-08-2013, 05:40 PM Thread Starter
I guess I'll order an IPR tonight. I went to ford today and got another CPS, because so many people think it is the problem. put it on tonight, no change....
Thanks,
Daniel
dkoehn is offline
post #4 of 8 Old 07-09-2013, 06:14 AM
Quoted: 169 Post(s)
Feedback Score: 3 reviews
Thanks,
Daniel
OMG Dude!!!
You're going to go broke replacing perfectly good parts, one after the other, until you get lucky???
That's not much of a plan, you could probably just take it to the dealership and come out a head
Do you know that for the cost of those three sensors you could purchase a diagnostic tool (the AutoEnginuity) that will direct you to the actual problem for the rest of your trucks life? (plus Many other vehicles you might run across)
And this could be no sensors at all. You could have a problem with your oil, the HPOP, the LPOP, ALL SORTS OF THINGS!
Calm down, step back, start looking at things logically....
NoRalPh is offline
post #5 of 8 Old 07-09-2013, 08:25 AM
Ramsmoker's Avatar
Put a gauge on the oil rail and crank her over. You should see a few hundred pounds for it to start and a little over 500psi idling. Cps would be my first thought but I have be working with IPRs lately and found you can really gain performance with more control.
The Ex -box. Total RSD system. See what happens when you let attorneys run your Country!!!! There's nothing wrong with a Democratic society, we just need to get rid of Democrats. 2001 Excursion. 2003 Cobra Terminator all pumped up. Now this is fuuuuuun.
Ramsmoker is offline
post #6 of 8 Old 07-09-2013, 08:38 AM
ADMIN AND TECH
SCUFFY828's Avatar
sounds more like and ipr issue , I did have a truck one day that the customer told me the same thing about spraying water on it and it would crank , ended up being a pump ,and ipr , I do agree with doing more diag before throwing parts at it
ITS STOCK
SCUFFY828 is offline
post #7 of 8 Old 07-17-2013, 08:41 PM Thread Starter
Thanks for all the help!!
I changed the IPR on July 11 2013, it started right up and has run great!!!
Daniel Koehn
dkoehn is offline
post #8 of 8 Old 07-18-2013, 12:44 AM
Quoted: 816 Post(s)
Daniel Koehn
Sweet. Thx for the feedback. :thumbup:
