Code problems -p1211 and p0603 - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-04-2013, 10:05 AM Thread Starter
emtp40's Avatar
I have a 2002 F250 7.3L 4x4. I just rebuilt my HPOP, Fuel Bowl, and High pressure lines. After that was done my engine light came on. It showed these two codes p1211 and P0603. 1211 reads injector pressure above desired pressure. P0603 reads Keep alive memory . I have replaced the ICP. The IPR and the pigtails on them both also.
I am asking for help to tell me how to get rid of the codes and how to repair the problem.
Thank you for your help in this matter.
Scotch Blair
emtp40 is offline
post #2 of 8 Old 07-04-2013, 07:46 PM
rfdunk's Avatar
Does your check engine light stay on? Do you have a chip or tuner on the truck?
rfdunk is offline
post #3 of 8 Old 07-05-2013, 08:44 AM Thread Starter
emtp40's Avatar
it does not stay on all the time. No chip,tuner, or programmer. the light comes on if i press on the padel to pass. Then some times it comes on around 40 mph. then while driving it goes off.
emtp40 is offline
post #4 of 8 Old 07-05-2013, 08:53 AM
timmyboy76's Avatar
anyway of reading oil pressure? Why the hpop rebuild? rebuilt or replaced? How many miles on her since replacing/rebuilding all thats mentioned?
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 8 Old 07-05-2013, 09:38 AM Thread Starter
emtp40's Avatar
It has been rebuilt. It has about 600 miles on it
emtp40 is offline
post #6 of 8 Old 07-08-2013, 10:56 AM Thread Starter
emtp40's Avatar
no way of reading oil pressure. Had to rebuild HPOP due to oil leak out of the so called non serviceable oil plug. Plus high oil pressure lines oil seals were leaking.
emtp40 is offline
post #7 of 8 Old 07-08-2013, 12:04 PM
timmyboy76's Avatar
future reference... Riffraff Diesel: Serviceable Long Threaded HPOP plug
you could have crap or damaged the ipr from re-installing.
post #8 of 8 Old 07-08-2013, 12:09 PM Thread Starter
emtp40's Avatar
i replaced the ipr after installing THe Serviceable long threaded HPOP plug
emtp40 is offline
