P1211 Code after replacing HPOP - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-01-2013, 01:39 PM Thread Starter
I just bought an 02 Ex (180K/Edge/KN intake/exhaust) and on the way home the check engine light came on! Had the code pulled and it was P1211 with I know is the ICP. I know the previous owner just had the High Pressure Oil Pump replaced. Is this common after a new HPOP? Any advice would be helpful...
atp47 is offline
post #2 of 2 Old 07-01-2013, 02:40 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
the code is probably from the edge.
the code is
oil pressure below/or above desired.
so im guessing that the edge set it off if you did a WOT run.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
