1999 Bending pushrods - Ford Powerstroke Diesel Forum
post #1 of 1 Old 06-25-2013, 12:17 PM Thread Starter
Hi All,
I have a 1999 with 305,000 miles on it. A few weeks ago when I was driving it threw the #5 exhaust push rod. I opened it up found the rod replaced it and continued to drive it the next day.
I was noticing a ticking sound after the replaced the rod that I had no heard before. Before I got a chance to check it out the truck starts running rough and lots of smoke.
I pulled the covers again to find that now #5 input rod is bent. Lookig for some advice.
What I have done
Compression test
The #5 10psi lower then the rest
AE Scan gives me p1298, p0266, p0275
I picked up some new o rings for 2 injectors and thought of swapping 5 with 7 to see if the problem follows the injector.
Not sure but I have read it can be so many different things.
Thanks
cflocation is offline
