low power - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-24-2013, 07:47 PM Thread Starter
cocoa2852's Avatar
low power
ok I got 99 f350 312k on it but lately it seems to be low on power I also noticed oil leaking under the intake in the back by the turbo was wondering if anybody had any ideas where I should start looking about two months ago I tried putting my super chips on extreme but it was slow as s--t so I put it back on light tow its like it not getting enough fuel or boost
cocoa2852 is offline
post #2 of 10 Old 06-24-2013, 07:50 PM
timmyboy76's Avatar
oils' from the ebpv rod assy, protruding from the pedestal. Remove the inlet to turbo, and try to move the wheel. Should not have any in/out, side/side play. Might be a good time to rebuild it all...
Riffraff Diesel: "Mechanics Parts Cabinet" Combo kit
Riffraff Diesel: Garrett GTP38 Journal Bearing Rebuild Kit
Welcome to BDrummonds Van Turbo Rebuild Web Page
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 10 Old 06-24-2013, 07:51 PM
timmyboy76's Avatar
Welcome to guzzle's In-tank Hutch Mod Web Page
post #4 of 10 Old 06-24-2013, 08:24 PM Thread Starter
cocoa2852's Avatar
when you say rebuild it all do you mean the turbo
post #5 of 10 Old 06-25-2013, 08:25 AM
timmyboy76's Avatar
thats alot of miles on a brass bushings. It doesnt take much to rebuild them either.
post #6 of 10 Old 06-27-2013, 09:23 PM Thread Starter
cocoa2852's Avatar
anything to do to modify it to make more power and get better mileage
post #7 of 10 Old 06-29-2013, 12:21 PM
timmyboy76's Avatar
my 2 pennies, first, fix the leaks and running properly, then worry about more power.
post #8 of 10 Old 06-30-2013, 06:22 PM
wireman116's Avatar
Check your fuel pressure, somtimes the sending unit in the tank go bad.
wireman116 is offline
post #9 of 10 Old 06-30-2013, 06:28 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Fix your problems and issues.
Then intake, exhaust, gauges, and no superchips but other tunes. TS at the minimum.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 10 Old 07-03-2013, 06:31 PM
Codum's Avatar
You need injectors. I had the same problem. Do you have a slight vibration at 1500-2000 rpm?
2002 F250 CCSB Lariet 7.3 Auto
2" helper springs 285/75R16 Toyo M/T
80 gallon fuel tank in bed
DIY 6637
Warn Premium Hubs
Ford Transmission @ 407,425 miles 3/24/12
Full Force Injectors
Avic X930BT w/ backup camera
"We Farm for Ducks"
As of 6/11/16 605,552 miles
2005 Excursion Eddie Bauer 4X4 6.0
Stock 225k miles
Codum is offline
