Miss after ipr went out. - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-23-2013, 12:43 PM Thread Starter
Ok so got another ipr in the truck new injectors and new oil cooler still missing.
All of this started after the truck died going around the corner from my house checked a few things found a guy with AE had him scan it was the ipr. I replaced the ipr. Then it started missing I figured it was from air in the system then 100 or so miles later still same thing going on. As I started above now put another new ipr in the truck new injectors still has a miss. Could the ipr going out have caused some sort of issue like internally?
Sent from AutoGuide.com App
shorty2tall is offline
post #2 of 3 Old 06-24-2013, 03:39 PM
Have you tried a new CPS?
Greenman01 is offline
post #3 of 3 Old 06-24-2013, 06:53 PM
timmyboy76's Avatar
remove the ICP plug and check for oil. If oils' present, replace icp..(located on d/s front of head).
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
