Up-pipes or just the gasket? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-23-2013, 01:25 PM Thread Starter
I have an an exhaust leak on the passenger side up-pipe where it connects to the turbo. I ask because I want to order only the parts I need because I'm not keeping the truck much longer and I want to have all the parts I need ready to go when I tear into this.
Here's a picture:
mechanicboy is offline
post #2 of 7 Old 06-23-2013, 02:06 PM Thread Starter
You know what, I've been looking at some pictures of people replacing the up-pipes and it appears that it has a sleeve that goes into the cast piece, meaning this is most likely the Pipes.
post #3 of 7 Old 06-23-2013, 02:15 PM
codyryan07's Avatar
most of the time its just a "gasket" or the donut.. they tend to waller out over time and do exactly that.. if you're planning to sell it soon, i'd just go with OEM replacement. If intentions change and you plan on keeping it, go with the brass donut upgrade from beans, or bellowed uppipes..
It depends on how hard the trucks been run, and how high EGT's have gotten in order for it to be the pipes.. they're usually fine, just bad gaskets..
Cody Ryan
03 f250 ccsb fx4 7.3
4" RC lift
35x12.50 federals on 20x12 rockstars
6637 intake, straight pipe
full RR w/ fuel bowl delete.
rebuild coming soon
codyryan07 is offline
post #4 of 7 Old 06-23-2013, 09:58 PM Thread Starter
Even when it's leaking like the picture? I was planning on replacing them with pipes from rockauto.com. They look bellowed in the picture and are only about $200 shipped which is cheaper than anything else I can find.
post #5 of 7 Old 06-24-2013, 07:23 AM
codyryan07's Avatar
i believe so.. bellowed up-pipes are going to have like an expandable steel around the top.. its kinda hard to explain..
kinda like these Free Shipping on International Bellowed Up-pipe Kit 99.5-03 1837872C93
hopefully someone else will chime in..
Cody Ryan
4" RC lift
rebuild coming soon
post #6 of 7 Old 06-24-2013, 07:47 AM
c69ss396's Avatar
Replace the doughnuts now and you will be doing it again later, Replace with bellowed up-pipes and never have to do it again..
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #7 of 7 Old 06-24-2013, 01:46 PM
blue99stroker's Avatar
Quoted: 244 Post(s)
the bolts are almost impossible to get loose as well.
and many times the pipes get worn out and wont re seal with new gaskets anyways.
bellowed is a good option.but if your selling the truck it might be cheaper to just get new stock up pipes or just try gaskets.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
