Vibrates at wot - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-21-2013, 08:22 PM Thread Starter
Vibrates at wot
As tirle says. When ibstep on it I feel a vibration. Where shoukd I start looking?
jchaussee is offline
post #2 of 5 Old 06-22-2013, 12:41 PM
Quoted: 822 Post(s)
U joints and carrier bearing. If you have the money, get a one piece driveshaft to get rid of the carrier bearing. You are within the allowable limit with a short bed.
Corey@CNCFAB is offline
post #3 of 5 Old 06-23-2013, 03:52 PM
Codum's Avatar
Does it do it at all RPM's. How many miles?
2002 F250 CCSB Lariet 7.3 Auto
2" helper springs 285/75R16 Toyo M/T
80 gallon fuel tank in bed
DIY 6637
Warn Premium Hubs
Ford Transmission @ 407,425 miles 3/24/12
Full Force Injectors
Avic X930BT w/ backup camera
"We Farm for Ducks"
As of 6/11/16 605,552 miles
2005 Excursion Eddie Bauer 4X4 6.0
Stock 225k miles
Codum is offline
post #4 of 5 Old 06-24-2013, 05:09 PM Thread Starter
No. just does,it at high rpms staarting around 2300. Has 305k. I will look into a one piecebdrive shaft, thoughit is not in the budget right now. I also have to do a front end rebuild because my steering has,about 2 inches of play.
post #5 of 5 Old 06-24-2013, 06:35 PM
Quoted: 822 Post(s)
Probably just needs balanced. Where ever u take it. Make sure their balance machine can do both pieces at the same time.
Also before you take it in check your phase alignment. Just Google driveshaft phasing. Its hard to explain typing on here. Lol :p
