2002 F350 7.3 Won't Start After Running Low - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-20-2013, 02:25 PM Thread Starter
I started her in the morning and realized she was low on fuel so I turned her off. I put 10 gallons in and she still won't start. I assumed that air got into the system so I removed the fuel filter cap and poured clean diesel with no air bubbles. However, she still won't start. She cranks and cranks but there is no start. I've charged the batteries several times to make sure they weren't giving out on me.
I have run out of ideas. Any thoughts or suggestions? Can I provide any more information? Please let me know if there is anything else I can provide.
I inherited this truck from my father who passed away recently. He always kept it running well. He maintained it daily and started it at least once a day to keep it in shape. I'm not well versed in engines and especially not diesel engines. What little I know I've tried. We don't really have any kind of money to consult a mechanic, so you all are really my only resource.
Yasmany is offline
post #2 of 4 Old 06-20-2013, 03:53 PM
Quoted: 171 Post(s)
Feedback Score: 3 reviews
My usual No Start -
WTS Light? - do you get it when you first roll-on the key? (shows the computer is running)
Is there fuel in the fuel bowl now? Does it refill after cranking? Look above the pass ft tire, you'll see a 3/8" metal tube, against the motor that ends there, it's the drain for the bowl (yellow lever you slide to the side). Get a cup, open the lever, drain the fuel bowl, look at the fuel, close the lever. Then, turn the key to the ON position (should hear the pump) for 15 secs. Drain the fuel bowl again, whaddya got?
Can you hear/feel the pump running (below the dr seat, against the framerail)
Is your truck "chipped"? If so, remove it as a Test
NoRalPh is offline
post #3 of 4 Old 06-21-2013, 11:33 AM Thread Starter
Originally Posted by NoRalPh View Post
My usual No Start -
You sir, have saved me a ton of money.
I made sure to the light turned off but I would also wait until I heard the pump stop for extra measure. I took your advice and emptied the fuel filter and turned the key to the ON position where the fuel pump should have refilled the filter, but it didn't. A friend and I took a look at it and turns out that the little motor inside the fuel pump was working but it wasn't pumping any fuel. We bought a replacement, installed it, and she started up! She needed a little help at first so we sprayed a little starter fluid into the air filter and she fired up and stayed on!
I seriously can't thank you enough. And just to answer the question, the truck IS chipped. Thank you, again!
Yasmany is offline
post #4 of 4 Old 06-21-2013, 09:56 PM
russtwentyfour's Avatar
Never ever ever use starting fluid, it will destroy your engine. Just do a search and you'll see why. Glad you got it going though, mine did this about 3 months ago. What caused mine was the pick up foot in tank fell apart got sucked into fuel pump and that's all she wrote. Realized this when I took old pump and shook it and small pieces of plastic fell out. Removed tank and cleaned the rest out, then went to guzzles site Welcome to guzzle's Ford PSD Web Pages did hutch and harpoon mods. Also built the fuel system he has on there, truck has been great since and mods where all well worth it.
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
