01 7.3 white smoke need help - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-19-2013, 07:49 PM Thread Starter
so i have been looking into this alittle bit and i dont know where to start.
white smoke on hard accelerations, no powerloss or other big issues. at first i was thinking injectors because apparently with diesels white smoke is unburnt fuel but today i noticed after doin an oil change a couple weeks ago i had to add 4 quarts of oill ..... is my turbo on the way out???? maybe bad seals hoping you can rebuild these, so basically oil loss and white smoke here and there.
mercurio51 is offline
post #2 of 7 Old 10-03-2013, 08:29 PM
lookin4myPSD's Avatar
I am having the same problem, minus the oil loss. I get a puff of white smoke mixed with black whenever I rev it, or accel hard.
Oh yeah...and by the way...
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
post #3 of 7 Old 10-03-2013, 08:35 PM
gingerbredman00's Avatar
Garage
White smoke with a blue tint to it is usually associated with bad turbo seals..
gingerbredman00 is offline
post #4 of 7 Old 10-04-2013, 01:11 PM
wick07's Avatar
well I can tell you as im in the middle of it right not, I chased my white smoke issue for a year. Changed every part on my engine it could be related to. I will tell you one thing. Don't waste your time. buy a $10 compression tester and test the compression.. I was in denial about it. Oh its my 7.3 I babied it... end result low compression cylinder 8. I now am trying to buy a used engine and have had 12 tested over the last 3 months. all 12 have low compression on atleast 1 cylinder and these engines range fom 72K- 240k now that kilometers not miles but you get the point
wick07 is offline
post #5 of 7 Old 10-04-2013, 03:24 PM
It's possible to bore out that cylinder and install a sleeve, isn't it?
Early 99 F250 ECLB,
post #6 of 7 Old 10-23-2013, 04:19 PM Thread Starter
Wouldnt low compression cause it too run poorly, loss in power, and even bad starts?? i understand where your coming from tho, ive pretty much pinpointed my problem im sure and i think its my o-rings on my injectors, ive checked the turbo, no end play and bone dry soot out the back. and the truck seems to run 100% plenty of power. like i said i go thru 1 gallon of oil every two weeks so im pretty sure thats my problem. my only other issue/question is would oil dripping thru the seals cause my truck to blow white smoke when floored, never at low rpms jus heavy to full throttle. i do have an edge programmer.
post #7 of 7 Old 10-23-2013, 06:33 PM
Macon's Avatar
Compression loss doesn't typically occur immediately. It's a slow loss over a period of time. You would never notice the loss of power unless one day you pulled a 15,000# trailer up the grapevine at 70, and then a year later you weren't about to get over 45.
There are many things that can cause white smoke while the engine is warm, and doing a compression test is a worthwhile thing. If nothing else, it gives you a baseline in the event of future issues.
wick07, is there a reason you can't just rebuild yours? I'm positive the machine work on yours would be cheaper than buying an unknown used engine.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
