NEW here! Truck does not smoke at full throttle. - Ford Powerstroke Diesel Forum
post #1 of 17 Old 09-30-2006, 06:22 PM Thread Starter
Matts99PowerStroke's Avatar
Question NEW here! Truck does not smoke at full throttle.
I just got my Power Stroke, it is a
1999 Ford F350 Power Stroke Super Duty Crew Cab 4x4 "Auto" 253K Miles
ATS Torque Pro 2000 Propane Injection System
50 gallon propane tank
Stage 2 Injectors
K&N Intake
3.5 Exhaust
Air Lift
100 gal. Spare Fuel Tank
NEW Tranny
NEW Transfercase
NEW Turbo
At full throttle it just does not smoke, I have even loaded up the motor still no smoke. Should I be worried!
K&N Intake & Filter
3.5 Exhaust No Cat & No Muffler
Air Lift
Autometer 3 pod w/ EGT, Boost, Trans Temp.
Matts99PowerStroke is offline
post #2 of 17 Old 09-30-2006, 07:07 PM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
Welcome to Powerstroke.org!
Someone will be along to answer you questions.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #3 of 17 Old 09-30-2006, 08:24 PM
The Fat Mod
Logan's Avatar
Welcome to the site. When you are trying to get it to smoke, are you using your drugs or just going off the motor alone? Sounds like you got a sweet set up.
Logan is offline
post #4 of 17 Old 09-30-2006, 08:43 PM Thread Starter
It was on all motor I have not touch the propane yet. I did go and look over the motor and found something that just make me so pissed off There is a injector just sitting under the turbo not connected to the intake manifold. How can a dealer not see something like that.
Now I need an opinion about how bad do you think it hurt the motor, not having an injector?
The max boost I hit while driving around was 21 psi. I have put about 50 miles on the truck since I test drove it. No tell how long the own drove it. Most of the time I was driving the truck had around 8 psi.
Now I am not a diesel person, but I have worked on a few cars in my time, just not diesel.
I was thinking that not having an injector in would burn valves and maybe melt a piston for the cylinder that the injector was out of.
Please post your ideas.
Thanks, Matt
K&N Intake & Filter
Air Lift
post #5 of 17 Old 09-30-2006, 08:53 PM
The Fat Mod
Logan's Avatar
As far as the injector, I am not sure. I do know that if you have a stock or stock size turbo, you max boost will be 24-25psi. Some get a little bit more and some get less. Depends on a lot of things. 21 does not sound too bad. What kind of guages do you have, analog or digital. That will make a difference in what you are seeing too. Did you put the injector back in? If so what happened?
Logan is offline
post #6 of 17 Old 09-30-2006, 09:14 PM
Moderator
00powerstrokin's Avatar
Send a message via Yahoo to 00powerstrokin
i find it hard tp believe that it only has 7 injectors in it. are you sure that they didn't just leave an injector laying under the hood when they installed the stage 2 injectors
2000 Ford f250 powerstroke. 6 speed, orange ext. cab 4 inch bds lift with 315/75/16 on eagle 589 wheels, k&n, straight pipe, autometer gauges, bully dog 6pos. chip,foil delete, DIY tymar intake, and homemade exhaust brake
00powerstrokin is offline
post #7 of 17 Old 09-30-2006, 09:30 PM Thread Starter
I got the truck with stage 2 supposed to be on it, the injector that I saw is connected to the harness. I did not touch it because I am going to try to kick the dealership in the a**. I am not going to start or move the truck until I talk to them.
The other thing this truck does not miss or run bad in any way. Why is that, you would think running only on 7 injectors it would run like sh*t.
K&N Intake & Filter
Air Lift
post #8 of 17 Old 09-30-2006, 09:31 PM
99Smokin73Stroker's Avatar
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
Yeah you would know that you were missing an injector. It's likely they just forgot that injector. Man those things are huge. As far as not smoking if you're getting enough air in the combustion chamber it will burn all of the fuel and there won't be any smoke.....
2005 F350 XLT FX4. 2.5" leveling kit, 03 turbo, 4" MBRP Turbo-back, 58v FICM, SCT X4, Irate Diesel coolant filter
99Smokin73Stroker is offline
post #9 of 17 Old 09-30-2006, 09:32 PM
The Fat Mod
Logan's Avatar
Yeah, thats what I was going to be getting at with the propane question. Dang, beat me to it
Logan is offline
post #10 of 17 Old 09-30-2006, 09:39 PM Thread Starter
Thanks for the help, if anybody else has an idea please feel free to post them.
K&N Intake & Filter
Air Lift
