Stranded no fuel need help!" - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-15-2013, 05:45 PM Thread Starter
2000 sd f250 7.3
Tried new fuel pump no luck
Tried new ICP no luck
Have 12volts at pump harness when key is first turned on no luck. Tried swapping relays behind radio no luck. Tried resetting the cutoff switch at the kick panel wasn't tripped. I
I'm lost need help any Info would be greatful.
bkmatlock is offline
post #2 of 5 Old 06-15-2013, 05:52 PM
jesilvas's Avatar
Quoted: 2 Post(s)
If you pull your fuel filter and drain the bowl, then turn the key on, does it fill back up with fuel?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 5 Old 06-15-2013, 06:29 PM Thread Starter
Broken wire at fuel pump. Prob pinched it enough to show voltage when tested. Prob fixed
post #4 of 5 Old 06-15-2013, 08:35 PM
jesilvas's Avatar
Quoted: 2 Post(s)
How'd it break?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 5 Old 06-15-2013, 08:45 PM Thread Starter
I was corroded green at the break. So it's been like that for sometime I assume. The plastic wire loom was crushed possibly from the front leafspring shackle. Its fixed now.
