oil leak - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-15-2013, 01:29 PM Thread Starter
oil leak
Hey everybody I'm sorry to ask this and I'm sure its been gone over but my high pressure oil pump is leaking and I was wondering if there was any way to fix it other then to replace it. I would like to rebuild it if I could find a kit for that any help would be great thanks Ben.
bman25509 is offline
post #2 of 4 Old 06-18-2013, 06:00 AM
If it's just leaking but works fine, your problem is probably a bad o-ring in one of the ports. You can repair easily at minimal cost. Just scan the powerstroke posts on high pressure oil pump leaks to get the details.
cheekme is offline
post #3 of 4 Old 06-18-2013, 07:57 AM
timmyboy76's Avatar
no, you cant rebuild them. The leak can come fro mthe hose ports or the "non" serviceable plug, which you'd have to remove the pump to "service".
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #4 of 4 Old 06-18-2013, 09:24 AM Thread Starter
Its the main service hole on the back of the pump
