Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
  #21 (permalink)
Old 12-18-2005, 11:12 PM
99Smokin73Stroker 99Smokin73Stroker is offline
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
I'm out of ideas now. I would say call around to some shops...
  #22 (permalink)
Old 12-29-2005, 03:24 AM
00powerstrokin 00powerstrokin is offline
Moderator
Send a message via Yahoo to 00powerstrokin
checked for codes last night before i dropped 400$ on a new pedistal. i didn't get anything. but i only drove it for about 10 min. before checking them
  #23 (permalink)
Old 12-29-2005, 05:40 AM
Veggie-Destroyer Veggie-Destroyer is offline
um o
the banks power elbow i installed is 4 in with no valve inside at all i allways wondered what that actuator was for . i assumed it is extra parts the stealer put on us to keeep the diesels down . no back pressure means less thingie tring to stop my spins e thinge from spinning . I like spinnie thinges:burnout .
no money then u need duct tape and the vice gips
remember to start all work with LARGE hammer and violently threaten your vehical while swing the hammer around yer head .. ok well it works for me
  #24 (permalink)
Old 12-29-2005, 08:48 AM
Moderator
so you did away with your ebpv
  #25 (permalink)
Old 12-29-2005, 02:34 PM
Moderator
will the stock exhaust bolt up to the elbow? how much was the elbow?
  #26 (permalink)
Old 12-29-2005, 04:16 PM
o um
i might but i dont think so cause it comes with 4 in down pipe . i think its onlt going from 3.5. to 4 . and yea i have 00 excursion with no valve-e ebpv in the exhaust . a cheaper way might be to buy one at recking yard and take the valve thing e out and weld closed the holes an waa laa this time duct tape wont do.
  #27 (permalink)
Old 12-29-2005, 07:40 PM
I thought the banks power elbow was just a cummins thing? I must not be researching hard enough!
  #28 (permalink)
Old 03-15-2008, 07:42 AM
jedspowerstroke jedspowerstroke is offline
hi wondering if replaced the engine temp sensor for the computer? if so where is it i need to replace mine and have no clue where it is thanks
