trouble on 95 - Ford Powerstroke Diesel Forum
Old 03-19-2008, 05:32 PM
trouble on 95
ok drove it today got her warmed up, shut her off came back 30 min later and when she started it shook so hard the dash on the pass side came loose!!! she then died, waited a min tryed to fire no luck 3rd try she lit off. it does have a fuel leak on top. im muffed anyone got a clue. also its a 5 speed and when your going and then push in the clutch it goes to a ruff idle got to give her some pedal to smooth out the idle
Old 03-20-2008, 05:12 AM
Old 03-20-2008, 05:28 AM
is everyone stumped with me?
Old 03-20-2008, 05:41 AM
Desert Shield/Storm Vet
Any codes?
Old 03-20-2008, 05:51 AM
Originally Posted by vitalidle View Post
Any codes?
gonna check this morning
Old 03-20-2008, 06:14 AM
pulled the codes and this one came up P0113 SUPERCHIPS BOOK says intake air temp circ high input any ideas as what that is?
Old 03-20-2008, 06:21 AM
Thats the intake air temp sensor that is the sensor in your air box. When is the last time you changed your fuel filter and oil? Also what oil are you running?
Old 03-20-2008, 09:18 AM
i put on the diy filter about a month ago, just bought the truck a month ago the sticker on the windshield say sits good for another 2400 miles and dont know about the fuel filter. i was thinking the same thing.
Old 03-20-2008, 09:26 AM
I would change it out and see if it helps.
Old 03-20-2008, 11:25 AM
what do you do with the air sensor on the diy intake?
