will not start without being plugged in - Ford Powerstroke Diesel Forum
Old 03-19-2008, 01:02 PM
my 2000 7.3 will not start without being plugged in (120v heater). I had the glow plugs system checked out and all was well. Is there another sensor that I might be missing? Garage that check it out said I might need a new computer, if so is the dealer the way to go on that?
Thanks
Old 03-19-2008, 01:10 PM
BIG TRUCK, SMALL DRIVER
Are the glow plugs not energizing, leading them to think it needs a new PCM?
Old 03-19-2008, 01:12 PM
No they are energizing, can't understand why it won't start with glow plug system working but will if engine is warm from heater.
Old 03-19-2008, 01:15 PM
How many miles is on it? I don't see how they could assume it needs a new PCM. If it does run the PCM is probably fine. Are they the ones that checked the glow plug system also?
Old 03-20-2008, 06:38 AM
Pipelayer they are the same, honest shop tho. The truck has 250,000 miles on it. When he pulled the codes on it he found two that indicated a faulty PCM.
Old 03-20-2008, 06:41 AM
Desert Shield/Storm Vet
Doesn't make sense to me as you need the pcm to start the truck whether its plugged in or not.
Old 03-23-2008, 04:03 PM
Beer Drinker/Ballast Guy
I had the same thing going a couple of winters ago. My truck wouldn't fire up even when 50+ degrees. I had to plug it in all the time. I changed the Glow Plug Controller and that solved the issue. Mine didn't throw any codes when it happened, and if it weren't for this website, I may still be plugging my truck in every night.
Old 03-23-2008, 04:13 PM
Thats Mr. Oil Leak.....
I would say check you glow plug relay etc.. and also check your battery cables. I just had a similar problem with mine and it was a bad battery cable.
Old 03-24-2008, 04:58 AM
one of my batteries was bad and i had the same issue. 2 bats and i was good.
Old 04-02-2008, 05:25 PM
powerstrokin
Send a message via AIM to drz400smoto
Hey what type of batteries do you guys recomend? I need to replace mine tonight...
