squealing when accelerating - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-09-2013, 09:00 AM Thread Starter
noticed the other day when i was accelerating from a stop sign that my Excursion had a loud squealing sound. of course i assumed the belt and checked it when i got home. belt is fine. no cracks and not dry. it only does this when the fan clutch is locked so i am assuming its the accessory drive system. when the engine was running it seemed that the upper idler pulley was moving just a wee bit so i replaced it and the belt to be on the safe side and it is still there. would a water pump do that? its not leaking and i have no shaft play.
greasemykey is offline
post #2 of 4 Old 06-09-2013, 06:30 PM
Jakeman711's Avatar
Sounds like a belt tensioner to me. If I were you I would try that. The spring on you old tensioner is probably worn out.
[SIGPIC]
99.5 F-250 4x4, 7.3 PS
Engine:
State 1 injectors from Rosewood, GT38 (van) turbo, S&B intake, Comp Cam's 910 valve springs, Smith Brothers pushrods, AIH delete TS 6-position chip. Pyro.
Body:
2005 front end conversion, 2008 tailgate, taillights, and rear bumper.
Future Mods:
Edge CTS monitor, and 4" Exhaust (Manufacturer to be determined).
Jakeman711 is offline
post #3 of 4 Old 06-18-2013, 01:59 PM
Quoted: 6 Post(s)
I had the same problem and it was my tensioner.
kilgeze is offline
post #4 of 4 Old 06-18-2013, 07:41 PM Thread Starter
i ended up replacing the tensioner the other day and it solved the problem. i forgot to get on here because i have been busy moving and selling my home. thanks for the heads up though.
