HELP!!!! My 1997 F250 Just died going down the road!! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-06-2013, 03:32 PM Thread Starter
jimhuntertx's Avatar
Quoted: 3 Post(s)
Send a message via Skype™ to jimhuntertx
Exclamation HELP!!!! My 1997 F250 Just died going down the road!!
I was driving down the road when she just died. No warning no smoke or anything, no over heating, oil pressure was good. I pulled over waited a min then she refired and died. I started her up again got home about a mile away. Got it in the driveway and now after checking the fuel filter, looks black but not full of grit or anything obvious. Now she won't start. I crank and crank, the oil pressure gauge stays down then suddenly goes to the middle of the gauge. I checked the dipstick and it looks like she might be a little low but there are no puddles or smoke anywhere. Can it be being a little low on oil cause the no run situation. What else could it be? CPS, FPR, HPOP? Please help me I can't afford to take her to the shop to get it fixed. Im fairly mechanical but this is my first diesel so I'm flying blind here. Again any help is greatly appreciated.
Jim
97 F-250 2wd Extended Cab Longbox, Pyro,boost and trans temp guage, 3" down pipe,
New E4OD Trans, TS 6 chip
Banks TransComander, 4" to dual 4" Bullydog 4" Dual Exahust , DIY Tymar intake w/ K&N Filter, Shimmed FPR
jimhuntertx is offline
post #2 of 8 Old 06-06-2013, 03:51 PM
Quoted: 172 Post(s)
Feedback Score: 3 reviews
CPS would be the likely place to start. You should always carry a spare anyway, so if you bought one and it didn't fix it you'd have your spare at least
NoRalPh is offline
post #3 of 8 Old 06-06-2013, 03:52 PM Thread Starter
Quoted: 3 Post(s)
I hate to sound stupid but
Where is it located? front of the motor on the passenger side right?
Jim
post #4 of 8 Old 06-08-2013, 04:36 AM
Jim
yes. about 11 o'clock if you were looking at harmonic balancer
barrakudaman is offline
post #5 of 8 Old 06-25-2013, 03:40 PM
Any update? Mine is at the point to where it will randomly stall at stop signs and even in the middle of a turn. Did it 3 times on the way home last night. Its an early 99 F350 SRW with 182,000 miles and original CPS.
None2Slow is offline
post #6 of 8 Old 06-25-2013, 03:45 PM Thread Starter
Quoted: 3 Post(s)
Yes, The shop I took the truck to replaced the CPS with a factory ford one and fixed the problem. They also went through the whole truck to make sure there was nothing else wrong.
So if you are running on the original CPS in your truck I would get another one from Ford and put it in there. It should fix the problem.
Jim
post #7 of 8 Old 06-25-2013, 03:52 PM
Thanks for the update, I'll get right on it.
post #8 of 8 Old 11-19-2013, 09:23 PM
Just an update to the update, I replaced the CPS and all is well with the world now.
