Water pump and pulley - Ford Powerstroke Diesel Forum
Old 03-16-2008, 06:09 PM
Send a message via AIM to tonypagnano
Pretty soon here im going to be changing my water pump and pulley. My belt squeaks like crazy and u can see the belt ride up and bump the edge of the pulley on the water pump making it squeak. I figure i will throw a new water pump on while i have it all apart. The only problem is i can't find the water pump pulley anywhere online? they want 70$ at a ford dealership so i might have to go with that unless someone knows of a place to get one? if so please let me know
Old 03-16-2008, 06:18 PM
ADMIN AND TECH
if the water pump is bad ,do you think the puley would be fine after the pump was replaced , the pulleys just dont go bad , tensioners cause belt squeak alot also
Old 03-16-2008, 06:23 PM
Im not sure if the water pump is bad or not. it was replaced at 36k and the truck now has 149k. Its just that i can see the belt "wabbling" but only as it goes towards the water pump pulley. i replaced the idler pulley. maybe i will try replacing the tensioners first.
Old 03-16-2008, 06:25 PM
ADMIN AND TECH
in all honesty , the tensioner is usuall sittin a little crooked and causing a squeal , on 9 out of ten trucks , did two last week,so i believe i would try that first , alot cheaper 2
Old 03-16-2008, 06:30 PM
ya i think i will then... also a lot easier. do u recomend replacing bot pulleys or just buy the whole setup?
Old 03-16-2008, 06:33 PM
ADMIN AND TECH
the whole tensioner setup, the pullets are fine its the tensioner itself that usually gets out of whack
Old 10-22-2009, 08:01 PM
ughh having the same problem... im gonna replace the belt but leave the water pump 125miles..? what do you guys think?
Old 10-22-2009, 08:52 PM
Send a message via AIM to lsmith33
i have a leak that looks like its coming from the water pump but not 100% sure how can i tell if it is the waterpump
Old 10-22-2009, 08:59 PM
Electrical Ogre
Originally Posted by SCUFFY828 View Post
the whole tensioner setup, the pulleys are fine its the tensioner itself that usually gets out of whack
Good point, and if left unchecked, it turns into a belt eater.
Old 10-23-2009, 01:02 PM
my god... ford wanted $500 for a water pump today... got it at lordco for $156 ... canada is ridiculous...
