Will coolant filter remove oil from the coolant??? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-03-2013, 09:05 PM Thread Starter
I've got oil in my coolant, and have discovered my oil cooler is leaking. I will be replacing the oil cooler o-rings, and going back together with Rotella ELC 50/50 after the drain.
I have already gone through the painstaking process of thoroughly flushing my cooling system when I made the transition to the ELC. Will I have to flush the entire coolant system again in order to remove any remaining traces of oil (as evidenced in my degas bottle), or would a coolant filter system help? Thanks guys.
2014 F250 Platinum
BakFlip F1
Line-X Bed Liner
WeatherTech Floor Liners
WeatherTech No-Drill Mud Flaps
DeeZee Tailgate Strut
5" Shorty Antenna
Big Wig rear anti-sway bar
Firestone airbags
B&W 16K Patriot 5th Wheel hitch
SOLD: 2001 PSD 4x4 Platinum Edition Lariat Auto CC SRW
Too Much To List
kep5niner is offline
post #2 of 2 Old 06-04-2013, 03:00 AM
schlutzer's Avatar
Quoted: 18 Post(s)
You'll want to run a full flush especially if your truck is like mine when I bought it, run for a while with a very badly leaking oil cooler. I drained it out, and flushed the rad, then filled it with a flush and distilled water then ran it for a day then this is what came out when I drained the flush out after the day
Took 2 more times for it to come out clean after a day, a year later my coolant looks awesome worth it to take the time the first time. Hopefully your's isn't nearly as bad as mine was, shame on you if it is. I had to pull ( and destroy ) the lower rad hose due to sludge build up clogging the rad drain.
schlutzer is offline
