Runs like cr@p - Ford Powerstroke Diesel Forum
Old 03-15-2008, 03:36 AM
Runs like cr@p
I went into home depot came out and it is running like crap. SES light comes on only while running. code reader wont read any codes. Any thoughts? It was running fine before stoping at home depot. I should have went to Lowes It is a 95 powerstroke no mods.
Old 03-15-2008, 03:39 AM
CRAUCH, , change the fuel filter lately? Poss. cam shaft sensor.
Old 03-15-2008, 03:44 AM
Almostdunfukinwidit
Crauch what kinda code reader are you using the generic ones dont read all of our codes. If the SES light is on you do have a code stored
Old 03-15-2008, 11:03 PM
Changed filter
!st thing I did was change the filter. I used a generic code reader. What code reader do you recomend?
I find it odd that it was running fine before i stopped all the sudden its running like crap.
Also the passengers side exaust it hot and the drivers side is cool enough to touch after an extended drive??
Old 03-16-2008, 02:24 AM
Well s#@$ happens. Snap-on makes a code reader(mt2500). I don't have one yet, heard they are good. Not just for reading codes. For self diagnostics. Also you could have a bad wiring harness under the valve cover to the injecters. Shoot the manifold with a heat gun and see what cylinders are cold. From what I've read, #3 and #7 usually have problems.
Old 03-16-2008, 04:47 AM
Almostdunfukinwidit
The one mentioned in the above post works. Or if you know someone that has the Auto Enginuity software that works great too. Another option is if you know someone that has an SCT or Edge programmer they pick up almost all our codes too
Old 03-16-2008, 04:56 AM
ADMIN AND TECH
not a fuel problem if check engine light coming on, like said before, get the codes out of it , if the cel came on there is code in there
Old 03-16-2008, 05:12 AM
With the temp differences on your manifolds, I'll bet on the UVCH coming loose. You need to pull your valve cover on the cold side and check the harness connection...
Tom in MO
Old 03-17-2008, 02:16 AM
Has anyone used pensacola diesel's rebuilt injectors??
Old 03-19-2008, 09:45 PM
update
I removed the offending valve cover. The harness looks great. No motoroil comming from the injectors. I read some where motoroil should be circulating from the injectors.?
