Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 03-14-2008, 05:03 AM
TONKA37 TONKA37 is offline
MY 99 POWERSTOKE WILL NOT START
I AHVE A 99 POWERSTROKE AND MY WIFE RAN IT OUT OF FUEL WE HAVE PUT FUEL IN IT AND IT WILL NOT START ANY SUGGESTIONS.
THANKS MATT
Old 03-14-2008, 05:35 AM
arisley arisley is offline
Turn the fuel drain handle (yellow handle behind the fuel filter) turn on the key. Wait until you see fuel draining under truck. Turn the drain hanle off. Start the truck. It will run like crap until you work the air out.
Old 03-14-2008, 06:06 AM
REDPOWERSMOKER REDPOWERSMOKER is offline
WE ARE DOOMED
Tournaments Won: 1
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
and if that dont work there are two fuel rail bleed screws on the back of the heads you can pull to get air out but try the drain valve first and if that dont work then try the bleed plugs...
