Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 03-13-2008, 08:55 PM
Gregch Gregch is offline
FPR shim
Just did the FPR shim mod earlier this evening, it went fine and the truck ran great. Drove her 4 or 5 miles to where I would be for a few hours. Truck ran great. On my way home I blew the filter cover gasket. I limped home another 3 or 4 miles, and watched my fuel gauge go from just under 1/4 to about empty at $4.29 a gallon. Last time I did a fuel filter I tightened it down as tight as I could by hand. I re-set the gasket and tightened the cap down with big water pump pliers this time. Do you think the cap wasn't tight enough? Did my pressure go ballistic? Do I take it out? It't not leaking now, but I am nervous. I have diesel everywhere, my clutch is slipping, what a mess. Thanks
Old 03-13-2008, 09:55 PM
fords4life fords4life is offline
Did you check your fuel pressure with a gauge? It is possible that your shim is too thick. From what I've read, the fuel bowl lid is the first thing to blow off if your pressures are too high.
Old 03-15-2008, 06:33 AM
I don't suppose that my clutch will come back will it? It got soaked with diesel also. Sorry about double post, don't know what I'm doing.
Old 03-15-2008, 06:37 AM
Hank Hank is offline
C.P.A. Officer
Don't know about the clutch....sorry.
I was ready to do the BB shim (it's still sitting right here by the computer) but decided to wait until I can install a gauge. I have read about what happened to you. I'd say you might want to take it back out until you can monitor the pressure. Just my 2 cents.
Old 03-15-2008, 06:53 AM
I did. Wish I was more careful and did a gauge first.
Old 03-15-2008, 07:05 AM
HVAC SuperTech HVAC SuperTech is offline
Scott loves the Squirell
Your clutch may come back, just may not be as good as it once was. Hope it didnt finish off your clutch
