Truck Dies and STARTS right back up.
This 99 F350 of mine is driving me nuts instead of me driving it. It purrs like a kitten and then all of a sudden it dies like shutting the key off. If I am going down the road when it dies it will kick back in if I keep it rolling in gear. I think it does it for the most part when the truck is cold. I have changed the CPS, The solenoid that runs the glow plugs. Took both valve covers off. Still does it.
. Any ideas? I am stressed over this thing.
Any codes?
Have you checked fuel pressure?
The engine light has never come on but will check codes Thur. If it was fuel pressure, Would it do it all the time?
Could be an icp sensor.
Nice truck Sawyer!! What is the ICP and where is it?
Thanks man, Injection control pressure sensor did a similaer thing to my pickup Id go get codes read from a good code reader the auto part stores cant read this code, It is located on the top of the driver's side head. It has three wires coming out of it. to see if thats the problem unplug it and drive around for awile if it doesnt die than you prolly need a new sensor. also check if it has oil in the plug. Hope this helps.
I will check it first thing in the morning and let you know. Thanks a million. I need to get my truck pictured on here too.
My icp sensor was actin up on me the other day too. id have it running and everytime id touch the wires itd die. Loose wires or somthing. got it fixed though.good luck
