2002 F350 no start - need advice - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-27-2013, 09:25 AM Thread Starter
Ogre's Avatar
Here is the thread I initially started under 911 Urgent Situations:
Need help, 2002 F350 no start
I'm at a loss of what to do or try next. Don't really want to take my truck to the stealership or anyone else for that matter...
To summarize here are my issues:
- turn the key and the WTS never goes off, stays on
- engine will crank over very fast but will not fire
- no fuel to the bowl
- can't pull codes from the data port because to communication with vehicle
- seems like PCM is not able to be communicated with
- batteries are good
- diso'd several sensors and no change to the symptoms
- can jump the fuel pump and it will run
- truck ran great for the last 3 yrs and drove to the gas station where it died, got it towed to my house
- much more info in above thread
Any help or advice anyone can give would be greatly appreciated. Thanks to all who have already posted.
Ogre is offline
post #2 of 7 Old 05-28-2013, 11:37 AM Thread Starter
Ogre's Avatar
Anyone? Anyone? Bueller?
Ogre is offline
post #3 of 7 Old 05-28-2013, 09:10 PM
Quoted: 818 Post(s)
Can you hear the fuel pump turn on when you turn the key on but not start it?
Corey@CNCFAB is offline
post #4 of 7 Old 05-30-2013, 05:41 AM Thread Starter
Ogre's Avatar
The fuel pump does not turn on when the key is turned. I can jump it with a battery and it runs. It's just not getting power/signal from the PCM or maybe IDM.
Ogre is offline
post #5 of 7 Old 05-30-2013, 05:41 AM Thread Starter
Ogre's Avatar
I found a PCM close by and going to get it today. I'll swap it in and post the results here. Not really sure if it's going to fix it, but I have to try something at this point.
Ogre is offline
post #6 of 7 Old 05-30-2013, 09:21 AM
Quoted: 818 Post(s)
I agree. PCM is a good start. I assume u did check your fuses right??
post #7 of 7 Old 05-30-2013, 05:22 PM Thread Starter
Ogre's Avatar
PCM fixed it! Truck starts and runs like a champ!
Thanks to all who posted and helped me with my no start issues! I really do appreciate it!
Brian
Ogre is offline
