01 7.3 won't fire up - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-26-2013, 11:15 AM Thread Starter
I have a 2001 f-250 7.3. About two months ago while driving down the road it just stopped running. There seemed to be a loud pop or click, and it just stopped running.
It cranks over fine. Had a newer fuel, and air filter and plenty of fuel.
Cam shaft sensor has been replaced twice since ( just to make sure it wasn't a bad part).
When I crank it. The rpm gauge moves up a bit, but the oil gauge doesn't move a bit.
I have been told that it sounds like the HPOP. This is a second vehicle, so is rather not spend a lot of money fixing parts that aren't broken.
I'm a stone mason by trade, but have fixed many others things with my trucks over the years.
ANY help is appreciated
Ovalover is offline
post #2 of 11 Old 05-26-2013, 11:37 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
If the oil pressure gauge isn't moving at all, it's more likely an LPOP issue instead of HPOP.
dhanna6powerstroke is offline
post #3 of 11 Old 05-26-2013, 11:54 AM Thread Starter
So are we talking the one inside the crank? Taking engine out and fixing it?
Ovalover is offline
post #4 of 11 Old 05-26-2013, 12:02 PM
Mod Newbie
Quoted: 19 Post(s)
That would be the one but the engine doesn't have to be removed to replace it.
post #5 of 11 Old 05-26-2013, 12:37 PM Thread Starter
Ok. So what makes you think it's the lpop and not the hpop? Can I do any kind of test to check ( maybe fill up hpop reservoir?)
Ovalover is offline
post #6 of 11 Old 05-26-2013, 07:40 PM
Mod Newbie
Quoted: 19 Post(s)
Your gauge shows LPOP pressure and not HPOP. The LPOP feeds the HPOP so of it's not functioning properly, the HPO system won't function. You need to check for base oil pressure first and then you really need a good scan tool or Auto Enginuity so you can monitor your ICP and IPR values. I'm not exactly sure how to check for base pressure on a 7.3 though. I mostly work on 6.0's but maybe someone will chime in here with some info.
post #7 of 11 Old 05-27-2013, 05:33 AM Thread Starter
Ok, I understand now. I read on another forum that if I fill up the hpop reservoir it should start up... Should I try this?
Thanks for all your help! Just trying to get my ole girl back on the road
Ovalover is offline
post #8 of 11 Old 05-27-2013, 10:33 AM
Mod Newbie
Quoted: 19 Post(s)
I don't know if I'd do it or not. If it would happen to start and you really do have an LPOP issue, you would be supplying any oil to the bearings and top end since the LPOP takes care of engine lubrication. I might not be correct on that but without knowing for sure, I'd be hesitant.
post #9 of 11 Old 05-27-2013, 05:41 PM Thread Starter
So today I took off the cover to the reservoir of the hpop. It was dry. I tried cranking the engine and no oil got pumped into it. So, I am guessing its either the draw tube or the lpop.
Ovalover is offline
post #10 of 11 Old 05-31-2013, 06:23 PM
I vote LPOP as a good starting point. Should not be to hard either. Grab a high volume LPOP from your local parts store. Should be about $75 bucks. You will need a harmonic balancer puller, 10mm socket and I believe a 15/16 socket and breaker bar. The old LPOP pump needs to go over the crank facing one direction, but the new pumps can go on either direction. Directions say to soak LPOP gears in oil for a bit before install.
I would also inspect the timing cover where the LPOP rides against. If there are any major scratches you will probably need a new front cover which does mean pulling the motor. I am betting that the cover would be scratched before the LPOP is bad. my 2cents
barrakudaman is offline
