Oil pressure problems - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-24-2006, 06:19 PM Thread Starter
larz18's Avatar
Does anyone know how the oil pressure is controlled in the motor?
i would assume that as the motor rpm goes up then the oil pump shaft spins faster thus increasing the oil pressure just like any other engine. The problem is My Turbo blows oil out the exhast side only at low rpms (under 1500). i have had the turbo rebuilt 2x in the past week so i know that is not the problem. Is there an oil pressure relief or something that controls the pressure or does anyone know what would cause this? THanks
GO GO BIG RED!
Sniper Tuner, RDP 2-stage water meth, ZEX NOS kit, 7 Autometer gauges, coolant filter, Trans lockup, High Idle mod, JOHN WOOD Full Billet Trans, TWINS! Holset HX-35/40 hybrid over HX-52 Pro Turbo, 255/200 II Hybrids, Adrenaline HPOP LPOP, 6 Stage Injector Pressure Module, 4" straight piped, Mag-Hytec Covers, RDP exhaust brake, DI Regulated Return, Aeromotive Fuel pump, Fuel Bowl Delete, Dual Tranny coolers, RDP Track Bars, SpynTec Conversion, 4.11 Yukons, 6" procomp lift
larz18 is offline
post #2 of 14 Old 09-24-2006, 06:25 PM
overl0rd's Avatar
Is it coming from the turbo itself? Does it go into the exhaust or does it go all over the motor? Look at the turbo pedistal with the motor running to make sure the orings aren't leaking and that the EBV actuator isn't leaking.
'96 F250 4x4 Ext Cab, 5 speed. K&N FIPK - modified to use 6637; 3" downpipe, 6" stack; Beans modded IDM; Beans stage 2s; shimmed FPR; exhaust brake; 6 position TS; locked 4.10s
'93 F250 4x4 regular cab long box. 7.3IDI nonturbo/E4OD 8' Western. STAYING STOCK
'65 Pontiac Tempest, 406ci chevy small block, TH350 with shift kit, 2700 stall converter.
'01 HD XL1200S - Lots of Screamin Eagle goodies
'96 Tbird LX V8
Progressive loves me
overl0rd is offline
post #3 of 14 Old 09-24-2006, 06:27 PM
mech2161's Avatar
Oil pressure works the same as any other. Sounds like you may have some type of restriction in the pedistal for the turbo drain. Does your oil pressure gauge read high?
Kevin
SPONSORED BY
Air Flow Systems
Terminator Engineering
DI Performance, South Bend Clutch
Discount Power Parts, Grand Rock
mech2161 is offline
post #4 of 14 Old 09-24-2006, 06:35 PM Thread Starter
larz18's Avatar
The oil is comming from directly inside of the turbo. The turbo pedistal is brand new. i took it off and checked all my orings and they were fine. i also ran water throught the pedistal when it was off to make sure there was free flow. My turbo shop said the same thing that there is probably a restriction in the drain down. The only restriction that i can figure would be inside the block itself becuase both the pedistal and turbo are brand new. One more question - does the high pressure oil system serve the turbo also or does that just serve the injector rails?
GO GO BIG RED!
larz18 is offline
post #5 of 14 Old 09-24-2006, 06:36 PM Thread Starter
larz18's Avatar
oh yeah and the oil pressure gauge reads the same all the time once its running just like any other stock gauge does. You turn it on and it goes right to the standard operating position. Sometimes i think those stock gauges are worthless.
GO GO BIG RED!
larz18 is offline
post #6 of 14 Old 09-24-2006, 06:43 PM
mech2161's Avatar
The center section of the turbo is cracked. It's not comon but it does happen. I would take it off and look at it close, it may have to come apart to see.
Kevin
SPONSORED BY
Air Flow Systems
mech2161 is offline
post #7 of 14 Old 09-24-2006, 06:53 PM Thread Starter
larz18's Avatar
that does not make sense to me. i had the turbo rebuilt 2x and both times he put on a new center section and put new shaft seals and bearings. it blew out oil both times. Any idea on how i can go about checking the drain down? Can i take off the oil pan to look up into the block or does the whole motor need to be torn apart?
GO GO BIG RED!
larz18 is offline
post #8 of 14 Old 09-24-2006, 07:12 PM
mech2161's Avatar
The cast center housing of the turbo?
Kevin
SPONSORED BY
Air Flow Systems
mech2161 is offline
post #9 of 14 Old 09-24-2006, 07:22 PM Thread Starter
larz18's Avatar
yup the part the mounts directly to the pedistal. he replaced that 2x and also the exhaust housing the first time.
GO GO BIG RED!
larz18 is offline
post #10 of 14 Old 09-24-2006, 07:26 PM
overl0rd's Avatar
The motor has to come out to drop the oil pan.
'96 Tbird LX V8
overl0rd is offline
