10psi of boost WOT???? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-21-2013, 12:33 PM Thread Starter
I only make 10lb boost at wide open throttle and only 15psi with edge programmer maxed on my attitude monitor. The truck has always felt a bit of a "dog" but I guess I should start with 99.5 F450 reg cab with workbox 4.88 rear 4X4 DRW short chassis. 9-10mpg avg, but with edge ez module i got 12mpg and that was set to max performance not fuel econ mode. My new edge with attitude monitor (I bought it used from guy) i can see parameters including egt's now but fuel econ didnt change. I neve see black smoke (unburne dfuel) from exhaust until max setting it puffed out a little. This does not seem normal. possible ebpv stuck?
ande6009 is offline
post #2 of 12 Old 05-21-2013, 12:51 PM
buckels's Avatar
Send a message via AIM to buckels Send a message via MSN to buckels Send a message via Yahoo to buckels
Check your uppipes, down pipe, up pipe collector, and exhaust manifolds for leaks(soot). If you dont have any exhaust leaks check your CAC boots. The only other things I can think of if none of these fix it is your wastegate actuator might be opening too soon or the EBPV is sticking. Hope that helps!
Drew
99 SD 6SPD manual
AFE Intake
Diamond Eye 4" turbo back exhaust
Wicked Wheel Gen2
PHP Hydra tunes by Bill
If you live in WA or OR check out these links.
buckels is offline
post #3 of 12 Old 05-21-2013, 12:52 PM
buckels's Avatar
10 PSI is WAY low.
Drew
99 SD 6SPD manual
AFE Intake
Wicked Wheel Gen2
buckels is offline
post #4 of 12 Old 05-21-2013, 01:05 PM Thread Starter
I checked all pipes and boots...no leaks, no soot no nothing all bolts are tight.
I guess a Banks big head is in my near future to see it factory one is malfunctioning.
ande6009 is offline
post #5 of 12 Old 05-21-2013, 01:36 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
doubt its the wastgate, the stock one opens at 8 psi anyways
if you cant find leaks then id say the EBPV valve is sticking shut.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #6 of 12 Old 05-21-2013, 02:01 PM Thread Starter
what should egts be if valve is stuck? would it be stuck open or shut?
2011 CCLB DRW 4X4 bone stock, but not for long
ande6009 is offline
post #7 of 12 Old 05-21-2013, 03:22 PM
timmyboy76's Avatar
One would think, you'd hear an awful sound coming from the downpipe/exhaust.
OP, i'm in same boat...no soot, leaks..etc anywhere. Even tried a different turbo, with the same results. 10psi wot, 14psi with redline unhooked...
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #8 of 12 Old 05-21-2013, 03:35 PM Thread Starter
I'll try unhooking redline and see what happens
ande6009 is offline
post #9 of 12 Old 05-21-2013, 04:22 PM Thread Starter
I took it for a small ride adfter unhooking red line, almost 19lbs boost. so I dunno what the deal is.
ande6009 is offline
post #10 of 12 Old 05-22-2013, 07:22 AM Thread Starter
Can someone explain to me what it means if more boost is created when redline is disconnected?
ande6009 is offline
