wont even crank - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-06-2008, 04:46 PM Thread Starter
wont even crank
99 f350 ps 75000 miles 1 owner Never had a problem till today 60 degrees outside drove 10 miles to work got in to go home wont start or even crank! I had a new cps in the dash after all that said about them just dying so I changed it out and still nothing. Checked headlights OK all dash lights on Radio and windows work but wont even crank! Put jumper cables on and it fired right up! Disconnected cables , turned off and it fired back up no problem, drove home 10 miles shut off and would not crank so cleaned battery cables put jumper cables back on and this time it wont crank. Tried several times , but luck. Put the Superchips tuner on to see if there was a code and it said p0602 Can anyone tell me what to do next?? I have got my recall letter from Ford on the CPS, just not made an appointment yet. THANKS for any info anyone will pass along! Steve
divedigger is offline
post #2 of 2 Old 03-06-2008, 04:50 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Sounds like a connection problem. Check all connections on batteries and to the starter.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
