HELP! truck is throwing codes and need to fix asap - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-18-2013, 04:04 PM Thread Starter
International25's Avatar
Ok went to pick my daughter up this morning and my truck was running fine. all of a sudden it looses boost and starts running like crap. idles weird. can barely hear the turbo. wont get over 35 40 mph. I get to her house turn it off and when i start it back up it runs fine. then on my way to work it does it again. info on truck. ok its a 2001 f 350 dually. 333,000 miles. i checked oil and all fluids and they are fine. i have an edge evolution on it. i drive around on the 3rd setting and pull with the tow setting. truck has never ever gave me any promblems. she is my baby and my daily driver. she is hooked to a trailer at least every other day with load sizes from 10,000lbs to 16,000lbs. i checked for codes and got these. ( P1316-inject. circuit and/or ism codes.) (P1211-inject. control pressure above/below desired). P0541- manifold intake air heater.
International25 is offline
post #2 of 10 Old 05-18-2013, 04:16 PM Thread Starter
ok also more info it is nearing time for a oil change and i checked for the codes with the edge dignostics.
post #3 of 10 Old 05-18-2013, 04:27 PM
nohsp4u's Avatar
I am going off memory but search the code as I think it could be your valve cover harness or the connector.
1997 F-350 XLT Lariat Crewcab long box 4x4. Oxford white with an ugly green. 133xxx miles. Hide away goose neck, banks turbo, exhaust, inner cooler, intake filter and gauges.
nohsp4u is offline
post #4 of 10 Old 05-18-2013, 04:40 PM Thread Starter
ok i will check both as soon as i get off work. i hope it is something as simple as that. i will look the codes.
LONG LIVE THE POWERSTROKE
post #5 of 10 Old 05-19-2013, 04:32 AM Thread Starter
P0603-PCM kam error code is also being thrown now. I don't understand. It ran fine when I started it up to leave work then it just lost power going down road. Feels like it is loseing half the cylenders. Turbo won't spool up. Im fixing to check the valve covers and the hook ups. But I feel like it is something to do with making the engine/injectors fire any input would be appreciated
post #6 of 10 Old 05-19-2013, 07:21 AM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
First, you can actually just ignore the 603. What it's saying is, that at sometime in the recent past, the PCM went unpowered (pull it, a fuse, or battery, you get that). Aslo, the 541 isn't anything to worry about either (the AIH isn't even necessary).
The two that are significant, are the 1316 and the 1211.
The 1316 is an IDM code alerting you to the fact that the IDM sees something wrong with the electrical control of the injectors (most often you'll find they aren't all firing, commonly, a whole side) and it needs to have you perform a Buzz Test on it to enable the IDM to narrow the problem down (you'll need a better piece of equipment to do a buzz test than a code reader)
The 1211 is about HiPres oil. There are Many reasons for you to get a 1211 and it too will require better equipment to help you diagnose and narrow down. Start with the basics, monitor the ICP pressure and IPR %. I don't much about your Edge, BUT because tuning often puts those HiPres values out-of-spec, for performance gains, it is not uncommon to have the 1211 get set and not have a real problem.
SO, if you feel like you've lost 1/2 the cylinders, that's where I'd start. You well may have. If you check for heat in the exhaust manifolds, compare the two sides, you can often find the "dead" side (sometimes it's just a matter of feeling them). Check the UVCH plug on the bad side carefully. If it's OK, follow the wiring from it back to the IDM for signs of chafing against things (valve covers and the like) and then suspect the IDM itself (which, because of its location, can get water in it)
Have a look at this vid ->
NoRalPh is offline
post #7 of 10 Old 05-19-2013, 09:59 AM Thread Starter
Ok thank you the video was very helpful. I'm just now working on my truck. My 4 year old keeps changing my plans on me. I'm taking the valve covers off now to see if if the plugs. Then ill go from there. Will let you know how it goes
post #8 of 10 Old 05-19-2013, 12:43 PM Thread Starter
Ok started raining and had to come in the house. But I did discover my driver side connection was loose under the valve cover. I had started putting valve cover back on when it started raining. Will let you know if this fixes my promblem
post #9 of 10 Old 05-19-2013, 01:30 PM
Quoted: 143 Post(s)
If it was partially unplugged, it will cause certainly this problem. Do the quarter trick to prevent it from happening again, but you want to be sure to inspect that plug to be sure the Glow Plug connections didn't get burnt away too...
NoRalPh is offline
post #10 of 10 Old 05-19-2013, 02:07 PM Thread Starter
Ok just got it started up and drove it around for a bit. Ran great 334,986 miles and still pulling strong. I was going to do quarter trick but discovered the connectors were broke off. So I just pushed back together and I'm fixing to order new valve cover gaskets and harnes. I would like to thank both of you for helping me. Lol I have discovered I need to rebuild my turbo maybe. Besides a clutch nothing has ever been replaced on my truck except glow plugs. Do you have any recommendations for wats to get more power that can be used safely while towing loads up to 16,000 pounds?
