oil sent
hey guys i have a 7.3 psd 2002 and i have been getting 9 mpg, but today when i got home i had a oil burning sent and what can it be?
Check the motor closely for oil leaks... you could also need injector o rings.. |
Ok
Bump, maybe a tech or someone will come along here to help you out.
ya i hope so and i will try the turbo things and how can you tell if the o rings are bad?
how many miles are on this truck, makes a big difference ,if you are smeeling oil, it will be an external leak, if it were o-rings for you to be able to smell oil you would also see smoke from tailpipe, which would tell me more of a turbo issue , even though turbos dot give alot of problems unless you have been puling heavy loads ad getting it hot , if its a stock truck turbo should be fine but as marc said good to at least check
i have 83k on it but it smokes bluesh grayish smoke when start up but thats about. but i did find that if you look into my tail pipe well running my eyes water and look at a truck like mine that didn't do that to me.
a little cold start smoke doesnt bother me , and with that mileage i wouldnt even think injector o-rings with that mileage , you cant really comare exhaust smell fom one truck to the other , thats not really a good comparison,make sure you dont have any external leaks , and make sure truck service is up to par
its all up and good and was told that by a ford dealer.
the dealer told you the service was up and good or did they check it for a leak
ya and there is no leaks at this time
