Low boost problem - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-17-2013, 05:18 AM Thread Starter
Low boost problem
Hello i am new to the site and new to the powerstroke.
I have a early 99 e350 ext van that is low on power, its only making 10 lbs of boost at wot and it takes a while to get up to 10 lbs.
No dtcs.
icp is 470 idle and 2400 wot
Backpressure 20-25 psi sensor is new and tube is clean.
Injector buzz test clears ok but cct fails on cyl nr 6
Map sensor, air filters and fuel filter are all new.
I have checked the intake boots and they look ok and i cant find any exhaustleaks in the manifolds or upp pipes.
Any suggestions ?
H.Lundberg is offline
post #2 of 7 Old 05-17-2013, 07:46 AM
timmyboy76's Avatar
subscribing....dont have a scanner ,but my truck is making duplicate #'s as you..(not sure about cct on my truck though).
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 7 Old 05-18-2013, 02:19 AM Thread Starter
I have not cheked fuelpressure att the filter bowl yet, could low fuelpressure cause these symptoms?
Can the cam sensor cause the cct fail?
post #4 of 7 Old 05-18-2013, 06:46 AM
timmyboy76's Avatar
with these motors, i'd say anythings possible. The cps (grey) usually, shows a failing test, on # / #8 cylinders, not the #6. Fuel pressure "could" contribute to low boost, but what f/p do you see?
post #5 of 7 Old 05-18-2013, 07:19 AM Thread Starter
Its a grey cps on it for the moment, Will measure the pressure att the bowl some time next week.
post #6 of 7 Old 05-23-2013, 10:21 AM Thread Starter
Fuelpressure was right at 60 psi att idle and wot, while i was in there i replaced the icp sensor and the van runs mutch better now. Thanks for all the tips
post #7 of 7 Old 05-26-2013, 08:01 AM
timmyboy76's Avatar
awesome news, lundberg..thanks for reporting.. Hows the boost #'s now?
