I know somebody has an answer for me - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-02-2008, 06:22 PM Thread Starter
TIMALEC's Avatar
ONLY GETTING THE P1210 CODE: i believe it's, injector control pressure at expected level
2000 psd. superchip. intake. exhaust. 153xxx miles.
Problems:
-doesn't want to idle at cold start. have to give it throttle to keep it running.
-hardly any power when cold (50-60 degrees out)
I've replaced the ICP sensor and it is working properly. The truck starts fine then it lugs and seems very underpowered when it's cold.
Today...i've checked fuses. checked icp. changed oil/filter. changed fuel filter.
The IPR vavle has also been checked.
I'm stumped so i'll let all you guys battle out the diagnosis.
Thx!
TIMALEC is offline
post #2 of 7 Old 03-03-2008, 05:43 PM Thread Starter
TIMALEC's Avatar
nobody??? somebody???
TIMALEC is offline
post #3 of 7 Old 03-03-2008, 05:47 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
I'm no tech, but have you tried having the HPOP pressure checked?
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #4 of 7 Old 03-03-2008, 06:13 PM Thread Starter
TIMALEC's Avatar
I haven't had that checked....Do i have to take it in to get that looked at or...?
TIMALEC is offline
post #5 of 7 Old 03-03-2008, 07:48 PM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 122 Post(s)
If you want to try to read it yourself, get a #5 ORB to 1/4" npt adapter, a length of hydraulic hose with 1/4" NPT ends and a 0-5000 psi gauge (should be able to get this stuff at a hydraulics place for about $25-30.) remove a plug in the cylinder head HPOP rail, install the gauge and hose, and crank the engine. Pressure should hit 2500-3500 psi during cranking if the HPOP system is operating correctly. If you try it out, post your results and someone should be able to tell you your next course of action
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
post #6 of 7 Old 03-03-2008, 07:53 PM Thread Starter
TIMALEC's Avatar
thx. i'll give it shot sometime this week after i round up the parts. I welcome any other suggestions to this idea and new ones.
TIMALEC is offline
post #7 of 7 Old 03-03-2008, 08:02 PM Thread Starter
TIMALEC's Avatar
Is there a tech
out there that agrees with this.. or has a different idea???
TIMALEC is offline
