99 f450, wont start,need help - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-14-2013, 08:34 AM Thread Starter
Wilson7397's Avatar
I recently purchased a 1999 F450 powerstroke automatic 4x4 350K miles from the farm that my buddy works at. The transfer case was blown apart, probably because it was never taken out of 4x4.It was running fine when the transfer case blew apart and broke the front drive shaft. They towed it back to the farm with a tractor and left it behind the barn. i bought it 4 months later. I can not get it to start, it wont hit off of ether
so far 'ive ...
checked all the fuses
the fuel bowl is full of fuel,
changed the cam sensor
checked the inertia switch
changed the IDM.
switched all the relays pertaining to the engine, pcm .idm
checked the fuel pump, it has power and is humming,
Everything looks normal under the hood, the oil resivoir is about an inch from the top, Im thinking there is a bad sensor, maybe the computer is fried, or the HPOP is to weak. Has anyone ran into this issue before?
Wilson7397 is offline
post #2 of 4 Old 05-14-2013, 10:51 AM
Quoted: 172 Post(s)
Feedback Score: 3 reviews
Do you get a WTS light when you first roll-on the key?
NoRalPh is offline
post #3 of 4 Old 05-14-2013, 02:40 PM Thread Starter
Wilson7397's Avatar
Yes, I've even had the block heater plugged in. I put a pair of optima battery's in it and it cranks really fast but it just won't fire. My code reader doesn't show any codes. I'm going to borrow my buddy's snap on scanner tomorrow and see if I can find a sensor issue.
Sent from AutoGuide.com App
post #4 of 4 Old 05-14-2013, 03:50 PM
Quoted: 172 Post(s)
That sounds like a good plan
NoRalPh is offline
