10k Mod Problem - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-13-2013, 06:38 AM Thread Starter
Jpsd99's Avatar
Question 10k Mod Problem
Hey everyone this is my first time on the forum and thank anyone that can give me some insight on my issue. First off ive had my truck only about a month with turbo back 4" straight pipe, 6637 intake and thats it. A friend told me to try the 10k mod said it worked gREATt so just for fun i tried it. Now when i turn the truck over it fires then immediatly dies. I unhooked mod truck started and ran. Next morning i tried it and same problem starts and immediatly dies. Did i fry my ICP? Any help is greatly appreciated! Thanks
Jpsd99 is offline
post #2 of 10 Old 05-13-2013, 08:26 AM
timmyboy76's Avatar
when you say, next morning, you tried it and it fired and died, WAS that with the resistor? If so, your probably crossing the wrong wires with the diode.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 10 Old 05-13-2013, 08:40 AM Thread Starter
Jpsd99's Avatar
Next morning it fired and died without the mod. I had the resistor in the red/grey blue/green pins on the sensor and i used a 1/2 watt resistor. I disconnected the batteries when i removed the resistor and plugged ICP back in and hooked batts back up. Ive also got a P1280 and P1211 code now.
Jpsd99 is offline
post #4 of 10 Old 06-28-2013, 02:01 AM
Any conclusion to your problem? I have a similar one.
Jimmycrackcorn79 is offline
post #5 of 10 Old 06-28-2013, 12:56 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
what is this "10k" mod?
2000-7.3L is offline
post #6 of 10 Old 06-29-2013, 12:21 PM
timmyboy76's Avatar
Poormans version of a chip/canned tuner..aka Edge. Guess it was a hot thing to do back 10 yrs ago.
post #7 of 10 Old 06-29-2013, 12:25 PM
Cowgirl forever!!!
SCPowerstrokecowgirl's Avatar
Quoted: 7 Post(s)
at least i wasnt the only one wondering what a 10k mod was
Jess
01 F350 Crew Cab 4x4 7.3 once again!!
MBRP 4'' Turbo Back and Chrome
05 Grille
Carolina Powerstroke Assocation member
LIFE IS TO SHORT SO RIDE A FAST HORSE!
SCPowerstrokecowgirl is offline
post #8 of 10 Old 06-29-2013, 12:32 PM
timmyboy76's Avatar
it "tricks" the pcm, thinking it has low oil pressure, so it re-adjust. Throttle response is off the hook. You want a smoke seen, install a lower resistor. 10k or 14.5k is what was usually ran. Mine dug the 10k, lit the tires up, throttle response was SUPER sensative and seemed to have more low-end poer, but thats probably the SOTP talking.
post #9 of 10 Old 06-29-2013, 03:26 PM
Sheesh.. How y'all have 1000+ posts but have never know what a 10k mod is? Is it something ppl only do on the OBS's?
post #10 of 10 Old 06-29-2013, 03:58 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Wow must be a 7.3 thing cause I never heard of it either.....
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
