sputters when wet? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 02-29-2008, 09:23 PM Thread Starter
sputters when wet?
OK guys my old man has an 03 i think its 01-03 7.3, and when it rains or the roads wet/slushy it seems to sputter. It doesn't stall, the rpms just fall to about 500 then back up... It does it on a full tank, empty tank, new oil, old oil, new fuel filter, old fuel filter, air filter.... blah blah blah, the moisture is the only variable that makes it do it... changed the cps for heck of it and still happens. light mods, edge, exhaust, and straight pipe.
The only thing i can think of is when i put his programmer in there was a conection on the front, bottom of the block, could moisture be gettin in there and breaking a connection? It has never happened in dry of powder frozen snow! JUST MOISTURE! any help would be greatly appreciated in know ur all smarter than me, so lets have it!
TheDurtyDeez is offline
post #2 of 12 Old 02-29-2008, 11:55 PM
cumminsturbo22's Avatar
being late that it is, ill find out tommorow bc my brother had the same problem on his truck, its a sensor i think for his turbo, everytime moisture was in the air the truck would sputter also, ill get back to you later.
cumminsturbo22 is offline
post #3 of 12 Old 03-01-2008, 04:07 AM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
Feedback Score: 4 reviews
I have also read where folks had water seeping through the windshield down the a-pillar and behind the dash. Here's a thread that talks about it. Here's another to look at.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 12 Old 03-01-2008, 10:51 AM
the sensor is a pressure sensor on the turbo when moisture is in the air it starts acting goofy. We went to the dealer to get it replaced cause the warranty wasnt up yet
post #5 of 12 Old 03-01-2008, 06:11 PM
lilredpowerstroke's Avatar
I knew this girl once who used to sputter when ........ uhhhhhhh you meant the truck!! My bad!!!
T.J.
2003 F-350 dually 6.0
Centennial Edition
Straight exhaust 34x10.50 Swampers on Black Rock Stars
Been a member longer than most of the moderators
Thats why I said most Tiff
Think you can trust the government? Ask an American Indian!
My old truck in action
lilredpowerstroke is offline
post #6 of 12 Old 03-02-2008, 08:51 AM
JPLTrucking's Avatar
I think mine is doing the same thing. It will be running fine, when raining or snowing, and then occasionally she will skip, buck, sputter (whatever you want to call it). Some time it will throw a light, but when the code reader is hooked up, no codes are showing. Same as you, only when its wet outside.
2002 F350 supercab 4X4, 7.3 PSD, auto
PHP Tuned /05 Grille /6637 intake /Zoodad /Gauges/ High Idle mod /Fog Light mod /LED Mirror lights/ Foil Delete /Walker BTM /SS HPX /285/75/16E BFG A/T /Coolant Filter /tinted tails and cab lights /5% Tint. SOLD
2001 F350 Reg Cab Dually, 7.3 PSD, auto
JPLTrucking is offline
post #7 of 12 Old 03-02-2008, 09:00 AM
Eric's Avatar
Feedback Score: 6 reviews
It could be the windshield wipers. Mine does the same thing, but only when the wipers are on intermittent.
Early 99 F250 with a bunch of extra junk...
Eric is offline
post #8 of 12 Old 03-02-2008, 04:05 PM
post #9 of 12 Old 03-02-2008, 04:13 PM
Eric's Avatar
Tell me about it. I know for a fact on mine it's when the windshield wipers are on that it bucks and acts goofy. I asked the service guys about it when I got my cps changed and they looked at me like I was stupid
Eric is offline
post #10 of 12 Old 03-02-2008, 04:55 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
It may be the CPS, when they start failing power spikes will disrupt them. Try running the wipers when it's not raining to rule out the water. i have seen this problem fixed by the CPS and like said before, sometimes it is from water running through a poorly sealed windshields an onto the generic electronic module (GEM). I would start with the CPS.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
