Glow Plug - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-10-2013, 04:08 PM Thread Starter
late4sho's Avatar
Glow Plug
Hello all again,
Well my truck has been throwing P1395, but is still firing up fine. But in this great state of California I have to get it smoged.
So I must fix the problem. I have researched the code and tested me GPR, and its fine. (side note first tested the air heater relay and no volts, I was so happy thinking easy fix, got the part then realized I checked the wrong relay)
My question is what is the part number for motocraft glow plugs for my truck? 1999
Also my truck is a CA Superduty but I can not see a GPC?
As always thank you for your help
D
MBRP 4" Turbo back Exhaust
AFE Stage 2 Intake
late4sho is offline
post #2 of 12 Old 05-10-2013, 04:21 PM
Jakeman711's Avatar
Motorcraft ZD-11 glow plugs. Ford also lists F4TZ12A342BA as a part number.
You do not have a GPR you have a Glow Plug Control Module. It is a silver box with two connectors on it, a black and a green. Ford part number YC3Z12B533AA
I have never trouble shooted one of those, so I can't offer much help. I know the Excusions have them too. If you need these parts buy them from Tousley Ford Parts. They are going to be your cheaped route. Call and ask for Mark he will take care of you. Make sure to ask for the online price. They ship fast and will have the parts to you in no time.
[SIGPIC]
99.5 F-250 4x4, 7.3 PS
Engine:
State 1 injectors from Rosewood, GT38 (van) turbo, S&B intake, Comp Cam's 910 valve springs, Smith Brothers pushrods, AIH delete TS 6-position chip. Pyro.
Body:
2005 front end conversion, 2008 tailgate, taillights, and rear bumper.
Future Mods:
Edge CTS monitor, and 4" Exhaust (Manufacturer to be determined).
Jakeman711 is offline
post #3 of 12 Old 05-10-2013, 05:00 PM Thread Starter
late4sho's Avatar
Thanks for the reply Jakeman,
I do have a glow plug relay, its right there.
AFE Stage 2 Intake
late4sho is offline
post #4 of 12 Old 05-10-2013, 05:13 PM
Jakeman711's Avatar
Are you sure it is not the AIH realy? If it has two relays next to each other then the truck didn't come from the factory with california emissions or someone changed it.
[SIGPIC]
Engine:
Body:
Future Mods:
post #5 of 12 Old 05-10-2013, 05:29 PM Thread Starter
late4sho's Avatar
Yes I have the two relays next to each other. And I have the no catalytic converter sticker under my hood, she's from Cali
AFE Stage 2 Intake
late4sho is offline
post #6 of 12 Old 05-10-2013, 06:40 PM
Jakeman711's Avatar
That's strange, somebody converted it then. It supposed to have the Glow Plug Control Module.
[SIGPIC]
Engine:
Body:
Future Mods:
post #7 of 12 Old 07-25-2013, 02:23 PM Thread Starter
late4sho's Avatar
-Update-
turned out to be my valve cover gasket.
Hope this helps some one in the future.
D
AFE Stage 2 Intake
late4sho is offline
post #8 of 12 Old 07-25-2013, 03:39 PM
timmyboy76's Avatar
why should it have a GPCM? My trucks a CA and it has 2-relays?
OP... thanks for the update.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #9 of 12 Old 08-01-2013, 05:22 PM
Jakeman711's Avatar
Ca emissions trucks came with a glow plug module. At least this has been the case with every Ca-emissions truck that I have worked on.
[SIGPIC]
Engine:
Body:
Future Mods:
post #10 of 12 Old 08-01-2013, 05:51 PM
jesilvas's Avatar
Quoted: 3 Post(s)
I thought the Ca had a GPCM too
4R100, 2wd
330,000 + miles
jesilvas is offline
