Wastegate Delete ? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 02-28-2008, 04:33 PM Thread Starter
Other vehicle is an F250
Hank's Avatar
Wastegate Delete ?
I did the wastegate delete a week or so ago. I'm undecided at this point whether I got any additional boost (no guages).
I also did the DIY intake a week or so before the wastegate delete. Love the open filter sound.
I have noticed the last couple of days that when I accelerate firmly and it shifts into high gear, I hear a rattling noise (not the swhoosh from the filter) that I would describe as a fan slipping on a shaft. I may be describing it this way because I am conscious of the turbo. I stopped on the way home tonight and hooked the red tube back up and it seems to have stopped.
Any idea what this is?
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #2 of 18 Old 02-28-2008, 04:43 PM
todd's Avatar
its not gonna make anymore boost your stock that line trick isnt going to do anything for you till you get a chip and boost fooler
traded it for an 06 dodge sorry
todd is offline
post #3 of 18 Old 02-28-2008, 04:46 PM
todd's Avatar
and just an fyi im for a better wastegate over unplugging the oem one
todd is offline
post #4 of 18 Old 02-28-2008, 04:47 PM
Stupidity pisses me off
sevenmalards's Avatar
Quoted: 9 Post(s)
I had a programmer and a boost fooler and it didn't seem to make a difference to me.
2006 F350 CREW CAB LONG BED KING RANCH
99.5 F350 Super Cab Long Bed, Dually.
SOLD
Originally Posted by SMKSTAX View Post
You are not right man, but i still think your funny as hell!
sevenmalards is offline
post #5 of 18 Old 02-28-2008, 04:50 PM
Hmmm, other guys running stock (no chips, boost foolers) said recently that the red hose plug trick was getting them from former maxes of 17-18 lbs now up to 21-22 with the wastegate delete.
I myself just did the delete trick this afternoon but have yet to take her out for a run. I just started it up and revved it up a couple times just to see if the boost would build off of a sitting truck...nothing happened, but I did notice a different sound from the turbo (?) that I hadn't before. Note: I had the truck's hood open and the door open so it wasn't like what I normally would hear driving down the road...but it was enough to make me think to myself, "Are you sure you want to do this?" I'm curious to see what others have to say, too.
losfinch is offline
post #6 of 18 Old 02-28-2008, 04:55 PM
scheidt27's Avatar
if you have a stock truck you will not build enough boost to hurt the tubo
2002 F250
Beans Diesel Performance Tunes
All Supporting Mods
scheidt27 is offline
post #7 of 18 Old 02-28-2008, 04:56 PM
todd's Avatar
your not gonna build boost just sitting there reving it you need to put it in gear brake and throttle at the same time "spooling" motor needs a load to boost
todd is offline
post #8 of 18 Old 02-28-2008, 04:56 PM
craig long's Avatar
todd, 2 things, when i did the wastegate delete it took my boost max from 17 to 25, i even noticed the throttle would press down another 1/2 inch. i have the mods in my signature and a 60hp single position chip. i am stacking the chip with a hypertech stage 3 programmer this weekend. which would help more, the annihlator or plugging in the better wastegate you spoke of...and where do i get one? thank you!
late 99 f250 7.3L 265k
4" lift, dual front shocks, adjustable air bags added to rear.
new calipers, brakes and rotors all around
isspro guages
rebuilt tranny with heavy clutches and shift kit. billet cowan converter.
finned front and rear diff. covers.
rhino liner bottom strips
cattle front bumper with 2" receiver, black steel rear bumper. 315/75/16 AT
diy intake
4" straight pipe
wastegate delete
ccv mod
foil delete
zoodad mod
craig long is offline
post #9 of 18 Old 02-28-2008, 04:59 PM
todd's Avatar
you need the annilator no matter what wastegate you use it keeps your map senor from defueling the truck and i use the banks bighead wastegate
todd is offline
post #10 of 18 Old 02-28-2008, 05:00 PM
craig long's Avatar
how much was that wastegate from banks? thank you
isspro guages
diy intake
4" straight pipe
wastegate delete
ccv mod
foil delete
zoodad mod
