Engine Seized - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-08-2013, 08:20 PM Thread Starter
Engine Seized
Ok so a couple weeks ago the truck started to idle really rough and seemed as if a cylinder wasnt firing so after some troubleshooting i replaced the injector in the #1 cylinder and the problems were gone and the truck ran great. The other day i drove the truck to work and it ran fine all the way there but started to smoke just before i pulled in and as i was parking it was smoking a fair amount. I shut the truck down then turned it back on and it was billowing smoke and then began to knock so i shut if off.
A few hours later i went back out to the truck and when i attempted to start it the engine began to turn over then stopped and wouldnt go any farther. The engine seemed seized. So i had the truck towed home and pulled the number 1 injector again and then turned the engine over by hand and it seemed to rotate fine. There was no fluid inside the cylinder.
So my question is what should my next step be? I was planning on either getting a compression test set or putting the injector back in and seeing if it will fire up.
Edit: Also the dipstick smells like pure diesel fuel
2000 F250 CCSB 7.3 PSD 6 Speed CFM Intake Manifold AFM Stage 2 Intake Snow Performance Water/Methanol Injection 160/100 Injectors GTP38R Adrenaline HPOP 203* Thermostat Air Dog II Gear Vendors Over/Underddrive 450HP Clutch 4.88 Gears ARB Lockers Mishimoto Intercooler Turbomaster Wastegate Controller 4" Turbo Back Exhaust DP Tuner Icon 4" Lift 37" Procomp Mud Terrains Fabtech Tration Bars
wallace2000 is offline
post #2 of 9 Old 05-09-2013, 02:08 PM
timmyboy76's Avatar
maybe bad orings on an injector/s. How many miles? Any other foreign liquid in the degas bottle?
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 9 Old 05-09-2013, 02:20 PM
c69ss396's Avatar
bad orings or a faulty injector,,,
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #4 of 9 Old 05-09-2013, 02:26 PM Thread Starter
I checked the temp on each exhaust manifold after warm up and the number 1 cylinder fails to warm up but that's where the new injector is. There isn't any other fluid in the degas bottle. It has 250,000 miles
post #5 of 9 Old 05-09-2013, 07:37 PM
Jakeman711's Avatar
Sounds like you got a bad injector, or the engine hyrolocked and the rod bent and there is not enough compression to start the combustion process. Whats the compression on #1?
[SIGPIC]
99.5 F-250 4x4, 7.3 PS
Engine:
State 1 injectors from Rosewood, GT38 (van) turbo, S&B intake, Comp Cam's 910 valve springs, Smith Brothers pushrods, AIH delete TS 6-position chip. Pyro.
Body:
2005 front end conversion, 2008 tailgate, taillights, and rear bumper.
Future Mods:
Edge CTS monitor, and 4" Exhaust (Manufacturer to be determined).
Jakeman711 is offline
post #6 of 9 Old 05-09-2013, 07:43 PM
Maybe when the injector was replaced or went bad the injector sleeve was damaged. Is there any signs of diesel fuel in the coolant bottle.
Its that or you will have to pull the vc off really quick and yank the glow plug.
Turn over the engine and see what comes out?
cfd_shop is offline
post #7 of 9 Old 05-09-2013, 08:58 PM
Jakeman711's Avatar
Yeah, it sounds like the injector stuck open and flooded the cylinder. In doing so the engine hydrolocked and either bent a rond or knocked out the injector. As the previous gentleman has mentioned pull your valve cover and have someone turn the engine over with the key from inside of the truck and see if oil is spurting out of the ejection spout on the injector. Please keep body parts away from belts, fans and other moving parts. In there is no oil the injector is not firing. Just becuase the injector clicks and the solenoid is working does not mean the injector is firing.
[SIGPIC]
Engine:
Body:
Future Mods:
post #8 of 9 Old 05-09-2013, 09:46 PM Thread Starter
Nothing came out of the cylinder when I pulled the injector. Also with watching for oil coming out of the the injector should the UVCH be plugged in when I try that?
post #9 of 9 Old 05-09-2013, 09:52 PM
Jakeman711's Avatar
Yes, if the injector is not pluged in then it will not fire. All eletrical connections must be intact.
[SIGPIC]
Engine:
Body:
Future Mods:
