Injector O Ring Question - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-20-2006, 03:41 PM Thread Starter
If the o ring between the hp oil recess and the fuel recess on the injector on a 7.3 were bad or defective, what would be some of the symptoms? High oil consumption? Oil in the fuel tank? Would smoke be worse, as the engine heated up and the tank level got lower?
buffalotg is offline
post #2 of 6 Old 09-20-2006, 03:48 PM
International Threat
Marty's Avatar
I believe oil in fuel however I'll get more info and get back to you.
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #3 of 6 Old 09-20-2006, 04:31 PM
Marty's Avatar
I did a search, I haven't come up with anything. Will let you know later if I find anything.
I'm sure Marc will know.
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
post #4 of 6 Old 09-20-2006, 08:15 PM
mech2161's Avatar
Originally Posted by buffalotg View Post
If the o ring between the hp oil recess and the fuel recess on the injector on a 7.3 were bad or defective, what would be some of the symptoms? High oil consumption?yes Oil in the fuel tank?yes Would smoke be worse, as the engine heated up and the tank level got lower?depends on how much oil in fuel
It's hard to determine what injector it is.
Kevin
SPONSORED BY
Air Flow Systems
Terminator Engineering
DI Performance, South Bend Clutch
Discount Power Parts, Grand Rock
mech2161 is offline
post #5 of 6 Old 09-20-2006, 08:26 PM
ill second that....
mschn99 is offline
post #6 of 6 Old 10-24-2006, 03:52 PM
Unhappy
i just lost one injector it split at the tip and blew out the o rings it wasblowing white fuel smoke +leaking oil out of driverside exhaust pipe to turbo. no warning just started knocking +lost power.i have about 230000 klms. canadian.other injectors on same side were o.k
mach1boy is offline
